Drivetrain Hello from a new Fox Body owner in Florida! Looking for advice on Immediate things to address re: steering, radiator, seat
Wareagle32789
10
Winter Park, FL
So I picked up a 1991 LX 5.0 5-speed recently and I'm just starting to work on it. It's been off the road for a while and needs some love.
It's pretty stock, showing 51,000 +/- miles (assume 150,000), but she's a little tired and needs some help. Looking for any advice on things to focus on first.
She runs & drives, but the steering is awful & noisy, plus the radiator is leaking and the driver's seat is messed up. PO said the bolt for the driver's seat broke, and he included a new floor pan with the car, so I'm thinking about finding someone to weld the new one in.
Thinking about going with an aluminum radiator with electric fans instead of the current setup. Any advice for what else to do would be appreciated. Don't know anything about these cars, other than having driven my Stepfather's 85 LX back in high school in the 80's.
Thanks!
Tom
  • Sponsors(?)
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
5,790
4,886
203
43
Welcome !!! If there are no sub frame connectors on the car I'd get some put in. You want the ones with the seat support brackets. The bad news is usually when the front of the seat breaks the bolt out it's because the rear floor pan may be cracked or flexing. ( that's the issue the connectors fix ) If the floor pan is cracked it's not all that hard to fix. Sounds worse than it is.
Check the front strut towers at the frame for rust. Get it up on a lift and checked out as soon as possible. Noise in the steering isn't good.
General karthief
Mod Dude
Aug 25, 2016
20,126
6,798
203
polk county florida
Something that may help the steering noise, if it is the pump that is making the noise, flush the steering system, get 3 quarts of power steering fluid and a good size bucket, I had the front jacked up so I used a 5gal bucket, run the return line into the bucket making sure it will not pop out, start the car and keep feeding the reservoir ps fluid until the color is good, shut off the car, reattach the line and top off the reservoir.
You could also add some Lucas ps additive too. Sometimes you just have to live with the whine. Sometimes you just got worn out stuff.
Wareagle32789
10
Winter Park, FL
OK. I actually have another PS pump that I picked up free from Craigslist. Perhaps I should just try installing the new pump and see what happens along with some new fluid.
Any suggestion on where to source the subframe connectors you mentioned? Are these "bolt on" items?
90sickfox
Mar 2, 2015
5,790
4,886
203
43
Our LMR discount code is in the vendors forum.
I recommend getting them welded on. Car has to be sitting level with weight o suspension. Body shops are the best place to get these done. They can also check and make sure the body us square before welding them in.
  • Agree
Reactions: 1 user
Wareagle32789
10
Winter Park, FL
[/QUOTE]
Thanks! I need some body work also. PO f'd up the driver's door and dinged the front fender while rolling the car around. When I got the car, the front fender was in the trunk. I grabbed a set of doors from a '90 LX at a U-pick junkayrd, and am trying to get them put on now so I can put the fender on.
Cheapskate207
The left one hangs a little lower
Jan 12, 2020
455
345
73
29
Maine
The SVE radiator from LMR seems to be the most popular choice. They sell fans specifically for it, in a package. I think I would opt for a set of ford contour fans though. A PWM controller in conjunction and you'll be good to go. I put a thunderbird fan on my current car controled by a DCC controller. I cant recommend the set up though, the contour fan on my old car worked better and DCC has poor customer service. Regarding steering... my car has a manual rack. It was installed when I bought it and I anticipated removing it but I've grown to like it. No whines, the engine bay is cleaner and easier to work on, and more power. The car is so light that it turns quite easy. Just a thought. If i were you I would try the new PS pump you have since it was free.
Reactions: 1 user
Steel1
Mustang Master
Aug 18, 2017
1,419
691
143
52
Connecticut
Check the rag joint in the steering shaft, it's like a 3" round rubber coupler , I'ts probably worn and causing a loose steering feel.
I would suggest replacing it with a solid steering shaft, you can get them from LMR, Maximum Motorsports etc.
They are a little pricey but worth it in imo, I did mine recently.
Reactions: 1 user
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,441
2,772
234
75
Dublin GA
lowendmac.com
@Wareagle32789
What is the nature of the seat problem?
Is the seat back broken or is it a problem with the mount where the seat bolts to the floor?
I have a fix for each of those problems that is a lot simpler and cheaper than replacing the floor pan.
Wareagle32789
10
Winter Park, FL
@Wareagle32789
The bolt that holds the seat to the floor in the back is broken, so the seat is loose and sits at a weird angle. The seat back itself seems a little messed up also. I'm new to Fox bodies, so I'm not sure what "normal" is, but mine sure isn't right. Hard to drive the way it is.
jrichker
Mar 10, 2000
27,441
2,772
234
75
Dublin GA
lowendmac.com
87-93 Mustang front seat repairs
The metal frame inside the seat back has probably cracked. It can be welded in most cases, but any repair that you do means removing the upholstery. The major trick here is the headrests off, and the how to do that changes with model years. The 89-93 have a single steel post.
See headrest removal | Mustang Forums at StangNet for the how to get the headrest off for these year cars.
The upholstery has a zipper that you unzip and then you can slide the upholstery off to repair the seat back frame.
The floor pan mounts for the front of the seats have also been known to crack and cause similar problems.
See Need Help | Mustang Forums at StangNet for the fix for that problem.
Reactions: 1 user
Wareagle32789
10
Winter Park, FL
Great info, thank you! I'm going with subframe reinforcement members with seat supports, which I hope will help with the root cause of the seat slump - I'll report back once I get the seat and carpet out and see what's going on...
Wareagle32789
10
Winter Park, FL
Just ordered the SVE radiatior, subframe connectors, fan controller, tstat & housing from LMR, plus some door parts. Thanks again for the advice - looking to do some social distancing and shade tree mechanic work as soon as the stuff arrives! I appreciate all of the great advice!
Reactions: 1 user
Wareagle32789
10
Winter Park, FL
Parts are on the way!
Reactions: 1 user
Blown88GT
2,172
518
164
Palm Beach Gardens, FL
The SVE radiator from LMR seems to be the most popular choice. They sell fans specifically for it, in a package. I think I would opt for a set of ford contour fans though. A PWM controller in conjunction and you'll be good to go. I put a thunderbird fan on my current car controled by a DCC controller. I cant recommend the set up though, the contour fan on my old car worked better and DCC has poor customer service. ...
DCC has great customer service, you just can't be in a rush during the summer season. It's a 1-man company & when he gets busy, he won't reply immediately. I recently changed to the Contour fan which requires a starting/running capacitor, I had it within a few days of ordering.
Willybill32
But at least it's tight!
Jul 16, 2019
279
109
53
Lexington, KY
Any particular year/model Contour fans? Looking at RockAuto.com, it looks like the dual fans are for the V6? How difficult is it to adapt the Contour fans to the Mustang radiator?
