Thats the way half the new guys are here.All this chatter an the OP is nowhere to be found
Cool gotcha, so the 4.00 bore would be better suited to stroke to a 331 or 347.You want the 4.125 Dart with the Siamese bores. Youre not going to get 363 inches out of a 4.000 bore dart block. If youre planning on a 363 youd want atleast the 190s but a 205 11r would fit the bill .
so block is the same but they just come in different bore sizes? The one locally is 8.2 4.00 it isn’t the biggest deal saver he was asking 1900 I was gonna see if maybe he will take 1800, meh saves me a couple hundred bucks and no freight pay. But...if it’s a better idea to go the 363 route by using the 4.125 bore then I guess I would just wait and order that block later down the line.They’re the exact same block. Both can be taken to near 4.200 and are Siamese bores
While I don't think a 347 to 363 is a big deal, I wouldn't pay that much to another individual.Cool gotcha, so the 4.00 bore would be better suited to stroke to a 331 or 347.
I was going to ask you about the motor bc I thought you had a 363 with twisted wedge heads yourself, so I was like it has to be possible. Then I do you say something about and it must be a story. Im sure you explained it in your thread. Are you happy with the 347? I guess I’m not understanding why there is a big bore. Like I looked around on fordstokers and they have 331,347,363 then options for big bore 331, 347 etc. I also get co fused with the piston option. I know TFS sells there specific ones, read another thread about some others used. Ford strokers has an option for twisted wedge valve reliefs but then the pistons options is something about flat top, then 14 or 20cc dished. Truthfully idk if I even need a 363 vs the 347, or whether it’s better to piece and build it slowly vs just saving and ordering one built from someone like ford strokers, chp etc.knowing it’s the same block now you can do whatever you want . I have a big bore 4.125 347 in mine . All it takes is the right crank and rods to get what you want
The big bore comes into play being that you start at 4.125 bore and then you use a 3.250 stroke crank like you would in a stock block 331 . So you get the benefit of being able to rev it higher with the added cubic inch . Where as a Stock production block 347 uses a 3.400 stroke crank to achieve the 347 inches and a 3.250 stroke to achieve 331 inches .I was going to ask you about the motor bc I thought you had a 363 with twisted wedge heads yourself, so I was like it has to be possible. Then I do you say something about and it must be a story. Im sure you explained it in your thread. Are you happy with the 347? I guess I’m not understanding why there is a big bore. Like I looked around on fordstokers and they have 331,347,363 then options for big bore 331, 347 etc. I also get co fused with the piston option. I know TFS sells there specific ones, read another thread about some others used. Ford strokers has an option for twisted wedge valve reliefs but then the pistons options is something about flat top, then 14 or 20cc dished. Truthfully idk if I even need a 363 vs the 347, or whether it’s better to piece and build it slowly vs just saving and ordering one built from someone like ford strokers, chp etc.
Ok so help me out. I'm trying to decide as well as I thought about getting Prestige Motorsports to build me a 427 as it's only $500 more than doing a 408 and 50 more rated hp. I'm not trying to do a max build and the car will not see the track. The 427 rated @ 500 crank hp/tq I'd be cool with 400-420 rw. The thing is for a long block it's around $8194. EFI car and manual N/A by the way.I've still yet to see anyone come up with a good explanation of why anyone would need a 427 over a dart 363 in a street car when running an aspirated engine.
What, so you can run like 3 pounds of boost less?
At this level of build, that number is negligible. If you were talking a stock 302 bottom end, a few lbs is a lot, each one creeps you closer to some level of risk, that's a time when lower boost matters.
I still believe the 351 adds complexity and cost, without really giving anything in return.
lo well I'm here now with a similiar question heheheeeAll this chatter an the OP is nowhere to be found
