Help 3k rpm idle wtf?
I'd first pull codes.
Absent codes, I'd disconnect the IAC electrical connector and see what the idle does. If the idle comes right down, you found the issue. If it stays high, look for a really big vacuum line that came loose.
Good luck.
Good luck.
I dont think its a vacuum leak, because the idle is constant just high, it doesnt try to die on me. I will investigate the IAC, and I dont think its codes because the check engine light isnt on when this is happening. I'm familiar with the IAC after owning a merkur...
