if I wana run late model wheels (2003 cobra) should I not redo the stock disk brakes in front? Would goign with a bigger rotor and PBR caliper help get the width I want?
from what I've seen these old brakes have the hub built in like GM used on the rwd cars and s10-trucks. The latemodel brakes have a hub behind the disks right? Simpler no?
can you explain the bumsteer situation with stock (disk brake)spindle setup? Do 17x9 fit in front?
