  • 1994 - 1995 Specific Tech
Help! Belt problems!!
  • Thread starter Thread starter stang3O2
  • Start date Start date Aug 22, 2004
stang3O2
200
Indiana
Aug 22, 2004
  • Aug 22, 2004
I have a 94 with with bypass smog and an underdrive pulley on the crank. I have had it like that for 20K miles. Just recently My belt has been slipping off the tensior pulley and getting wedged there and shredding. It has done it several times now. What is the deal? Would pulleys just become out of line for no reason? Do I need a new tensior? Please Help
Thanks
Matt
R
Rerun
312
South Bay, California
Aug 22, 2004
  • Aug 22, 2004
Does your tensioner read between the Range markings?
stang3O2
200
Indiana
Aug 22, 2004
  • Aug 22, 2004
yes it does
thanks
matt
baglock1
The Bartender
6,612
Space Coast, FL
Aug 22, 2004
  • Aug 22, 2004
Take a look at the tensioner to make sure there aren't any obvious signs of damage to it. Put a ratchet on it and and test to make sure that the tensioner spring is still putting out an adequate amount of force. The spring could be broken which would explain the problem.
Also, stand on one side of the motor and sight down the face of the pulleys to check for a bent pulley or accessory shaft. This is easiest done while the motor is actually running as the tell-tale wobble will be much more obvious. Of course, you can always run a straight edge across the faces too but it's absolutely critical that the edge is absolutely straight.
Unless something catastrophic has happened recently though, I doubt a bent pulley is the case. Pulleys and shafts don't bend on their own. Of course, if you've had the belt overly tight, that could do it.
on edit:
Another possible cause is one of the accesories being loose in it's mount. Double check them too.
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
R
Belt size
  • ron2shel
  • Oct 12, 2023
1994 - 1995 Specific Tech Oct 13, 2023
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
What is it Worth?!?!? May 18, 2026
nickyb
