Help, car hasn't been started.....
  • Thread starter Thread starter Wil
  • Start date Start date Jul 18, 2007
Wil
581
Burke, VA
Jul 18, 2007
  • Jul 18, 2007
Ok, I've been a really evil mustang owner. I lost my license about 5-6months ago but haven't started it since, I know it really really REALLY bad for a car not to be started so what do I do now?? Do I change the oil before I attempt to start it ( battery is dead but will get a new one) Someone told me about a "cold start", what ever that is.
I NEED SOME SERIOUS ADVICE, i DONT WANT TO LOSE MY ENGINE. THANKS!!
bill302
2,131
alabama,gadsden
Jul 18, 2007
  • Jul 18, 2007
what you are calling a cold start is When an engine has been sitting for a time, the internals become dry and need lubrication. in your case i would inspect all fluids, fill if needed...pre-lube or prime the engine without actually firing it up. if you have knowledge of removing the distributor and priming the oil there with a drill and shaft extension to manually operate the oil pump this is the method i would use. i have experience at this method and experience with installing and removing a distributor properly, if you dont have this experience i would not remove the distributor. i would remove the spark plugs while marking wires so they can later be installed properly then Spray a small amount of penetrating oil into the spark plug holes and then turn the starter over for a few(3), 6-10 sec intervals. allow starter to cool approx. 20 mins and repeat. this should lubricate the internals after doing either of these methods i usually listen after turning oil pump or cranking of the starter into the oil fill hole after removing the cap you should be able to hear oil draining into the pan,(ya you can actually hear it). when you hear this you know oil is being circulated properly. reinstall plugs and wires...then i would add some new gas on top of the gas in the tank..6mos old gas is not too bad though as long as its sealed properly with a gas cap unexposed to atmosphere....then i would crank drive a short distance allowing it to reach operating temp....park then change oil...
Wil
581
Burke, VA
Jul 19, 2007
  • Jul 19, 2007
Wow, guess I've got some work ahead of me. Some one told me that I should take the wire off the coil then try to start it so that the engine will crank but not start...is this also true?
90topdown
138
Philadelphia, PA
Jul 19, 2007
  • Jul 19, 2007
If you pull the coil wire off the distributor , engine will crank but not run.
The cold start method listed by bill302 is the correct way to do for an engine that has been sitting for a long time. But if you are not fully comfortable with the procedure of pulling the dizzy and priming the oil pump, I would not do it.
Six months is not that long really..
IMO, I would just pull the coil wire so it wont run and crank the engine over a few times until you see oil pressure on the guage. Then recconect the coil wire and fire her up!!
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,120
224
Massachusetts
Jul 19, 2007
  • Jul 19, 2007
6 months is nothing.
I used to go 9 months over the winter between starts.
My poor car hasn't started in 3 years now
Wil
581
Burke, VA
Jul 20, 2007
  • Jul 20, 2007
Thanks god! Thanks for all your help guys, going to call a buddy of mine to do what bill said, if he can't help. I do the coil thing.
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
  • dan50
  • Jul 18, 2026
dan50
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
