Help dad fix his a/c
  • Thread starter Thread starter darthcual
  • Start date Start date Jul 6, 2005
darthcual
985
Arlington, TX
Jul 6, 2005
  • Jul 6, 2005
I know this is the mustang forums but i thought you guys might have an Idea. After about 100 miles travel time in my dads truck 2002 dodge ram the a/c would stop blowing cold? I thought maybe his fan clutch but it appears to be working, the condenser has an electric fan but it is also working. Could the problem be the belt? The truck has 60000mi on it and is the 4.7litre if that makes a difference.
Car RamRod
Banned
Mar 30, 2005
623
Queens, NYC
Jul 6, 2005
  • Jul 6, 2005
we're no help, find a dodge forum Im sure theres one out there.
BLOWN 5.0 FOX
213
NORTH SHORE MA
Jul 6, 2005
  • Jul 6, 2005
There is a known problem for the condensor fans crapping out on that model year ram- but if that is definetly operative- then your out of luck here. Check the condition of the condenser to see if the fins are blocking air flow. Good Luck with that
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jul 6, 2005
  • Jul 6, 2005
How much freon is in the system?
C
coming4you
32
Toms river NJ
Jul 6, 2005
  • Jul 6, 2005
ac
im a technician... First off weather it be ford,dodge, chevy, whatever doesnt matter ac is ac
If you have a set of ac gauges connect them to the high and low side of the ac system... Start the vehicle and turn the ac system on max... make sure your ac compressor kicks on... At that time get your gauge readings... the high side on a hot humid day shouldnt go much over 200 but should stay around 180 190... and the low side should be somewhere around 25 to 40 no higher
if the psi arent within these then you most likely have a leak... And then i suggest bringing it to a dealer or local shop... they will have to reclaim the system add ac dye and then check to see where the leak is coming from ...
i hope some of all of this helps
mike
darthcual
985
Arlington, TX
Jul 7, 2005
  • Jul 7, 2005
Thanks for the advice all.
BLOWN 5.0 FOX
213
NORTH SHORE MA
Jul 7, 2005
  • Jul 7, 2005
For the record I too am a technician and my post was from a Dodge TSB - and AC is AC....but Dodge is Dodge- they are a problem in themselves. Sorry darth but what do you expect from a Ford Forum
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • dan50
  • Jul 18, 2026
dan50
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
