Well I drained the oil out of my differential and put the cover back on. i am have a problem filling it up. I pump oil into it but it seem that it just pours back out the level check hole. I know it not full,so any help would be great.
Yeah I am sure it notr full becasue when i drive it around the block and hit a bump I can hear the the gears knock becase of no oil. I am using premixed.
its hard to believe you have that much gear play. if you did, it would make niose with or without oil. had it been run out of oil at any time? sure then you dont have bad suspension bushings or the snubber is worn down?
I notied that it is was starting to leak from the bottome of the cover so I took to cover off and raplaced the silicone on it. I put some oil in it and it was ok for a few days. Then i noticed that it made and thunk sound when i went over a big bump. So I checked the level of oil in the diff and i could feel any oil so I tried to put more in but it just spills out and i check to see it i can feel oil in the check hole but there is none.
