HELP ! DTE ODO DATA ERR
  • Thread starter Thread starter GT-1
  • Start date Start date Dec 12, 2010
G
GT-1
Kuwait
Dec 12, 2010
  • Dec 12, 2010
hi everyone ..
i have a 2005 whipple'd mustang gt , the car was in '' failsafe engine mode '' and it was horrible , i cleaned the intake and the throttle body and flashed the car , took it to the dyno and everything was perfect and it was running good . yesterday i started the car , drove it for 1 or 2 miles , then it suddenly stopped ! and i got these msgs '' fule level low , dte odo data err , check charging system '' ! and the car would not start ! any idea ??
SpartaPerformance
2,517
61
89
Long Island NY
Dec 12, 2010
  • Dec 12, 2010
Sounds like you may have a "brain fart" that stuck in self test mode. Disconnect battery and try reflashing the PCM again properly.
G
GT-1
Kuwait
Dec 14, 2010
  • Dec 14, 2010
I did what u said , and I got the same mags when I was flashing the car, and it didnt work ! Any ideas ??
SpartaPerformance
2,517
61
89
Long Island NY
Dec 14, 2010
  • Dec 14, 2010
Have you checked for codes?
G
GT-1
Kuwait
Dec 15, 2010
  • Dec 15, 2010
Some say that the codes I got could be from the bettery or the alternator ! But I don't think so cuz I've had them for less than a month !!
There was a member here that had the same codes , and he got it solved by changing some fuses !! What do u think ? Can I do something before I take it to the shop ?!
SpartaPerformance
2,517
61
89
Long Island NY
Dec 15, 2010
  • Dec 15, 2010
I meant if you have any codes in your PCM
G
GT-1
Kuwait
Dec 16, 2010
  • Dec 16, 2010
What do u mean ?
SpartaPerformance
2,517
61
89
Long Island NY
Dec 16, 2010
  • Dec 16, 2010
If it's in fail safe engine mode like you said then the "check engine" light is on. You need to hook up a scanner that can read trouble codes. Perhaps the problems are linked.
G
GT-1
Kuwait
Dec 17, 2010
  • Dec 17, 2010
It was in fail safe engine mode and yeah the check engine light was on , but as I said when I cleaned the air intake and the throttle body and flashed the car , everything gone ! And the car was perfect . After a few days it stopped and showed these codes !
SpartaPerformance
2,517
61
89
Long Island NY
Dec 18, 2010
#10
  • Dec 18, 2010
  • #10
From the description your giving me with multiple error messages, according to the procedures I've read it seems to point to a bad instrument cluster or bad wiring or wire connection.
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
T
Electrical Fuel level Low, DTE ODO data error
  • TeddyBxar
  • Jun 30, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Jun 16, 2026
Nathan G
N
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
