HELP:Engine rotates but does not start 93LX
  • Thread starter Thread starter tonyvlx
  • Start date Start date Oct 20, 2006
T
tonyvlx
12
Woodbridge,Ont
Oct 20, 2006
  • Oct 20, 2006
I went to go start up my car today. Engine has a healthy rotate but does not fire up. I have fuel pressure, i checked the coil with ohm meter, and i do have spark. The car seems tempremental when starting. Sometimes it fires up and somtimes it just rotates. Could this be a distributor or TFI problem?? Is there anyway i can test to see??? Any help would be appreciated THANKS
HISSIN50
34
129
Oct 20, 2006
  • Oct 20, 2006
See Jrichker's 'Cranks but no-start checklist'.
You need to do the diagnostics when it's acting up and wont start. More info about patterns of when it chooses not to catch might help.
The first step is to pull codes.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 20, 2006
  • Oct 20, 2006
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 18-Oct-2006 to include TFI fault during crank/run cycle
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. See paragraph 3A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
J.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) 86-93 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
billison
I like tinted tail
2,607
1,094
184
stl
Oct 20, 2006
  • Oct 20, 2006
B.) Coil
C.) TFI module
H.) Computer
B.) Distributor cap
C.) Rotor
Two reasons:
I'm gonna paste copy all your stuff and try to beat you to the punch for now on...
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 20, 2006
  • Oct 20, 2006
You would benefit far more by understanding the troubleshooting methodology behind my posts. Break complex systems into subsystems. Work through the subsytems one step at a time, isolating the the good from the bad. When you are done, you have some valid conclusions to work with so that you can fix it right the first time.
billison
I like tinted tail
2,607
1,094
184
stl
Oct 20, 2006
  • Oct 20, 2006
yes...yes i would
T
tonyvlx
12
Woodbridge,Ont
Oct 21, 2006
  • Oct 21, 2006
Guys i swapped out my complete distributer with anouther one. Same problem
I know my Roller Rockers need adjustment, could that have anything to do with it. THANKS
Also im using the Crane HI6 Box,could there be something wrong with it. But i am getting spark.
billison
I like tinted tail
2,607
1,094
184
stl
Oct 21, 2006
  • Oct 21, 2006
have you just took some time to look at everything to see if something came unpluged?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 21, 2006
  • Oct 21, 2006
Go through the checlist I posted one step at a time and you will find the problem. It has a better than 95% sucess rate.
stangjunkie
381
#10
  • Oct 21, 2006
  • #10
the other 5% lied about really going trough it
T
tonyvlx
12
Woodbridge,Ont
Oct 22, 2006
#11
  • Oct 22, 2006
  • #11
ya same thing with other distributer. i checked for spark again, its giving a very thin yellow spark as apposed to a healthy blue one. could it be my crane ignition box???
billison
I like tinted tail
2,607
1,094
184
stl
Oct 22, 2006
#12
  • Oct 22, 2006
  • #12
check the ground..and read the checklist
HISSIN50
34
129
Oct 22, 2006
#13
  • Oct 22, 2006
  • #13
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
  • brandyn200
  • Jun 20, 2026
AeroCoupe
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
