  • 1994 - 1995 Specific Tech
HELP: FUSE PANEL MAP
  • Thread starter Thread starter xc_myers_06
  • Start date Start date Feb 14, 2006
xc_myers_06
64
Nebraska
Feb 14, 2006
  • Feb 14, 2006
Hey i don't have my owners manual so could someone scan me off a copy of their manual or give me a detailed copy of what fuses do what in the fuse box under the drivers side and also in the distribution box under the hood. I got a 95 GT if that helps any, but i am guessing all have the same fuse layout.
bill302
2,131
alabama,gadsden
Feb 14, 2006
  • Feb 14, 2006
here you go i have 3 pics. to post last pic will be in next post...
bill302
2,131
alabama,gadsden
Feb 14, 2006
  • Feb 14, 2006
last pic. hope these help...i'm just learning how to scan and send pics. these should print out fine. you just need the top portion of this scan below its a continuation of 2nd page in first post...
Frank.Rizzo
47
Central Oregon
Mar 24, 2006
  • Mar 24, 2006
I can't see the diagram . . . does anyone have this?
HISSIN50
34
129
Mar 24, 2006
  • Mar 24, 2006
This might help, courtesy of Bikewiz.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Mar 24, 2006
  • Mar 24, 2006
Frank.Rizzo
47
Central Oregon
Mar 24, 2006
  • Mar 24, 2006
Thanks to BOTH of you!
Hey, thanks to both HISSIN50 and bill302 for the diagrams. These forums are always a great place to talk with people!
I am looking at the diagram and I don't see where there is a fuse for the turn signals. Does anyone know if the blinkers are controlled by a "flasher" module or something? I remember my old truck had some sort of a flasher module and not fuses. Does anyone know?
Thanks again!
Frank Rizzo
bill302
2,131
alabama,gadsden
Mar 24, 2006
  • Mar 24, 2006
Thanks again!
Frank Rizzo
check your e-mail and let me know if info. helps.
bill302
2,131
alabama,gadsden
Mar 24, 2006
  • Mar 24, 2006
if your flashers are inoperable it will more than likely be fuse #1 under dash or flasher module located where i told you in the e-mail.but it can be the bulb too. the signal filament can be burned out and running lamp filament could be good. does both left and right turn signals not work and if one side works and other doesnt this usually indicates a bad bulb. but if lamps dont work at all this will usually be a bad fuse #1. and if lamps work and signal doesnt work this usually means a bad flasher module....
HISSIN50
34
129
Mar 24, 2006
#10
  • Mar 24, 2006
  • #10
To add to Bill's advice, testing the lighting with the use of the Hazard lights can be helpful (this rules out bulbs, etc, since it uses a separate flasher relay).
Bill - hope I didnt step on any toes - I wasnt seeing diagrams earlier so I posted the link.
bill302
2,131
alabama,gadsden
Mar 25, 2006
#11
  • Mar 25, 2006
  • #11
thanks for the advise HISSIN50 i overlooked the hazzard lights good looking out thats why were all here. ya i e-mailed him the diagrams.don't worry about stepping on any toes with me i'm getting educated for free on this site i have learned alot from you and others...
Frank.Rizzo
47
Central Oregon
Mar 27, 2006
#12
  • Mar 27, 2006
  • #12
Problem Solved!
Just to summarize, none of the turns signals on either side worked and the emergency flashers would not come on, but the parking lamps worked.
There are two fuse boxes for the '94 GT, one in the engine compartment and one inside the car, under the dashboard, just above where your left leg sits.
I was told by several helpful members of StangNet that it would either be a blown fuse, a bad bulb, or the flasher relay box itself. The flasher relay box is a yellow box that sits just behind the interior fuse box and is connected to the fuse box by a slide connect and a plug.
You can rule out a bad flasher relay if both your emergency flashers and your turn signals stopped working as they apparently use different flasher relay boxes. If just the turn signals don't work, you may have a bad bulb or a bad relay. Luckily, for me, it turned out to be a fuse problem and not a bad bulb or the flasher box itself.
The signal/flasher fuse is the "number 1" fuse and is 15amps (light blue). The diagram I had was for a '95 and didn't quite match my '94 fuse box layout, but there were only five fuses that were 15 amp, so I pulled each one and, sure enough, the last fuse that I pulled was blown.
I replaced the blown fuse from the spares in the lid of the fuse box cover and everything works again. Thank you very, very much to "HISSIN50" The Green GT" and "bill302" for taking the time to help me out!
HISSIN50
34
129
Mar 27, 2006
#13
  • Mar 27, 2006
  • #13
That's great to hear you got it, and wonderful that you posted a follow-up to help future searchers.
TGGT and Bill are both great assets to SN.
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 5:36 PM
AeroCoupe
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Electrical Fuse 8, Light Green / Black Wire
  • bleedinggreen
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 26, 2025
bleedinggreen
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
