HELP HELP HELP !!
  • Thread starter Thread starter stangrider08
  • Start date Start date Apr 6, 2008
stangrider08
Houston, Tx.
Apr 6, 2008
  • Apr 6, 2008
i need some help right here. I have a mustang GT 2004. The engine is great and everything is working perfect but when i start the car and push the clutch theres a noise coming from the engine and its weird what could it be ?
mustang50v8
548
847 Chicago Burbs
Apr 6, 2008
  • Apr 6, 2008
i have no idea what you just said. decrease the font size. take it out of bold and italics and reword the statement. what kind of noise? noise what general area do you hear it? how many miles on the car?
stangrider08
Houston, Tx.
Apr 6, 2008
  • Apr 6, 2008
it comes from the engine or transmission and the car has 15 240 miles and sounds like a diesel truck lol but i change the oil every 3000 miles and i take it to the dealer to do all that stuff and now i dont have money to take it again and find out what could it be
BurningRubber
1,865
24
58
Apr 6, 2008
  • Apr 6, 2008
Have you checked your oil level? Color of the oil?
Piston slap seems to be a problem with some of these engines... it will sound like a diesel untill it starts to warm up.
stangrider08
Houston, Tx.
Apr 6, 2008
  • Apr 6, 2008
yeah but still when the car is hot still doing the same noise and yeah i did check everything and i don't know what is going on with it ! cause the car runs great and theres not a problem when i drive it fast
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 7, 2008
  • Apr 7, 2008
Is it while it's running and you push the clutch in you hear it, or just on start up? Could be anything from a bad throw out bearing in an already running car, to loose timing chains on cold start up?
screamin gt
5 Year Member
Apr 9, 2007
393
central CT
Apr 7, 2008
  • Apr 7, 2008
try taking a video and posting it up so we can hear what your talking about.
mustang50v8
548
847 Chicago Burbs
Apr 7, 2008
  • Apr 7, 2008
much better now that you fixed it!!
if the noise is only when you push the clutch in i would think that it is the throwout bearing.
what does the noise sound like? squealing, squeaking, knocking, ticking? also how many miles on the car?
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 7, 2008
  • Apr 7, 2008
stangrider08
Houston, Tx.
Apr 7, 2008
#10
  • Apr 7, 2008
  • #10
that noise comes when i push the clutch in !! whenever i turn on the car cause when i put it on neutral the noise is gone
stangrider08
Houston, Tx.
Apr 7, 2008
#11
  • Apr 7, 2008
  • #11
and the car has less than 19 000 miles and its a ford mustang gt 40th
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 7, 2008
#12
  • Apr 7, 2008
  • #12
But what I'm asking is, does it make the noise when the car is already running. Like say when you're sitting at a stop light in neutral and push the clutch in, to get it into get. With the statement above, you make it sound as though the sound is only heard on start up?
stangrider08
Houston, Tx.
Apr 7, 2008
#13
  • Apr 7, 2008
  • #13
its when the car is already running and yeah when im sitting at a stop light in neutral and push the clutch in that is when i hear the noise
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 7, 2008
#14
  • Apr 7, 2008
  • #14
Ahhh, then in that case I'd look at your transmissions throw out bearing as being the problem and either tear into it yourself, or have one of your local mechanics take a look at it to confirm.
Anyone else have a different opinion?
blkhorse
345
Apr 7, 2008
#15
  • Apr 7, 2008
  • #15
lightly push down on clutch pedal,do not release clutch. If you hear noise, it's the throwout bearing. if the noise is only present with the clutch to floor it's more than likely the pilot bearing. ethier way time to pull trans. might want to upgrade clutch while your in there
stangrider08
Houston, Tx.
Apr 7, 2008
#16
  • Apr 7, 2008
  • #16
yeah it happens just when the clutch is all the way to the floor
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
