HELP! Idle problems!!!
  • Thread starter Thread starter hmrdwn88lx
  • Start date Start date Sep 4, 2006
hmrdwn88lx
Hsv,AL
Sep 4, 2006
  • Sep 4, 2006
I have an 88 lx 5.0. I am having some idle difficulties and it doesn't appear to directly be the iac. I can let it sit in my drive way and it will sit there and purr just find, usually. But about 80% of the time while im driving down the road, idle will just surge up to between 2000 and 3000 rpm and stay their until I turn the vehicle off. I can stop and turn the car off and back on and idle will return to normal, at least initially. I have stopped when this has happened and left the engine running, gotten out and disconnected the IAC during one of these surging episodes. And the idle goes back to normal. I plug it back in, and the idle goes crazy again. This led me to believe that the IAC was bad, but I have gone through 3 new IAC's, and it makes no difference. Obviously something is sending the IAC incorrect signals. I have ABSOLUTELY no clue as to what it is. If anyone out there can help, I'd really appreciate it. Thanks.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 4, 2006
  • Sep 4, 2006
See "Help me create the Surging Idle Checklist" at http://forums.stangnet.com/showthread.php?t=534062
for help with your idle problems. The first post contains all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
HISSIN50
34
129
Sep 4, 2006
  • Sep 4, 2006
Though it sounds like an IAC issue, if not:
A tip from Jrichker is that this is a sign of a bad TPS (carbon breakdown in the wiper, or something to that effect). The idle will run-up and hang. The fix is to restart the car and it will be ok till it hangs up again.
The IAC seems likely, but just in case...........
Good luck.
EDIT: He beat me anyhow.
hmrdwn88lx
Hsv,AL
Sep 7, 2006
  • Sep 7, 2006
thanks
thanks for the input. Im gonna try the checklist, for right now though, I have just unplugged the IAC and manually ran the idle up just a little so its driveable. Rides great like that, but Im not the "unplug it and forget it type" i wanna fix the problem. thanks.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
M
Idle control valve
  • miser143
  • Oct 31, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 1, 2026
General karthief
