help im leaking something need help identifying it
  • Thread starter Thread starter mat82284
  • Start date Start date Aug 11, 2004
M
mat82284
889
  • Aug 11, 2004
my car was running fine intill someone slashed my tires so i sat in my garage for 5 days never ran then i start it up when i get the tires on the back it out and take for a drive there were 2 puddles 1 small small oil leak and there was a medium puddle about 4 inch circle of a orange red substance it could have been orange yellow but i couldnt tell it looked orange to me. it was on the right side of the car where my smog pump connects too. also i dont have a smog pump but the hose is just sitting there with nothing pluging the whole should i plug this whole???
Kdubslugga
1,515
Akron, OH
Aug 11, 2004
  • Aug 11, 2004
not sure but, once i saw someone who had orange radiator coolant instead of the typical green, what color is your coolant?
battyice
153
West Chazy, NY
Aug 11, 2004
  • Aug 11, 2004
If the liquid is red or orange I would guess it is power steering fluid. It could also be transmission fluid leaking from a hose going to your tranny cooler. If you're not running an automatic, I'd suspect your leaking power steering fluid somewhere.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 11, 2004
  • Aug 11, 2004
The orange coolant is Dexcool. Powersteering and tranny leaks seem to happen more often when the systems are running and under pressure/heat -- but I think the other guys have id'd the possibilities.
M
mat82284
889
  • Aug 11, 2004
yea it was 105 deg today. if its power steering what can i do to stop the leak? i put in that lucus stuff a wile back because it leaked but it didnt leak to the ground where i can see it like it did this time.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 11, 2004
  • Aug 11, 2004
You need to find out what/where it's leaking. There are many possibilities from a bad high pressure or return hose, fitting, or the steering rack itself, pump seal,.....
P
PonyBoy90
555
Toronto
Aug 12, 2004
  • Aug 12, 2004
Simple way to check if it's power steering fluid is to check your pump reservoir. If it's unusually low, you have a leak somewhere on one of the two hoses, if not both. How's your steering? Has it started stiffening up?
I just got this problem recently. Mine seems to be leaking somewhere where my 2 hoses meet the rack and pinion by the steering coloum. I hope it's a hose and not the rack else I'm looking at a replacement or rebuild.
dastang2
2,020
tx
Aug 12, 2004
  • Aug 12, 2004
does the PS pump whine when idleing and turning
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 12, 2004
  • Aug 12, 2004
My replacement pump whines more than the stock one did - neither leaked. I just tell 'em it's the supercharger.
R
Rerun
312
South Bay, California
Aug 13, 2004
#10
  • Aug 13, 2004
  • #10
P
PonyBoy90
555
Toronto
Aug 13, 2004
#11
  • Aug 13, 2004
  • #11
Yeah, the power steering pump does whine, especially when doing sharp slow turns. A whining pump is not reallly a good indication that the pump is going bad. Same goes for a whining fuel pump.
The PS pump isn't bad until it become difficult to turn due to the pump itself going bad, or you spring a leak somewhere.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Aug 13, 2004
#12
  • Aug 13, 2004
  • #12
econo supercharger..all the sound without the expense.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 13, 2004
#13
  • Aug 13, 2004
  • #13
Correction - all the sound and none of the fury without the expense....
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Aug 13, 2004
#14
  • Aug 13, 2004
  • #14
As always you are correct sir.
dastang2
2,020
tx
Aug 13, 2004
#15
  • Aug 13, 2004
  • #15
well what i meant by asking that was, when you get super low on PS fluid, you hear the whining louder. so if the PS is leaking it may be getting louder thatn usuall.
Help Identifying Engine Harness Plug
  • FoxbodyRob
  • Feb 7, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Feb 7, 2026
FoxbodyRob
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
C
Need Help identifying this small black box
  • Cholly2991
  • May 28, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2025
99SvtCobraTx
9
D
Resolved Help Identifying Sensor Part Under the Hood on 3.8L V6 1994 Mustang
  • DPP
  • May 27, 2025
1994 - 1995 Specific Tech May 27, 2025
DPP
D
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
