*******Help Im missing window parts
Steve69
233
Hi Guys,
I took my 69 fastback apart about 10 yrs ago and finally getting it back together.
I had a new front windshield installed and they installed the new chrome moldings
for me. Problem, The lower molding looks like there is 6 brackets that must slide
in the lower molding and screw into the cowl. ***Anybody have any extra
brackets they would part with. Let me know how Much $ you want for them.
Question 2: I also had new side windows installed and the drivers sid window
was hard to open before. Now its a 2 hand job. It seem like all the pressure
is on the outside weather stripping belt. Is there anything I can do to take the
pressure off or lube the door gears. I also have new weather stipping installed
also.
Thanks a Million
for the help
I tink the clips are the same as 65 up to 70 so look at a set. the window can be adjusted by the track bolts inside the panel, must take off the door panel though.
Loosen them up but dont take out, if the window then goes up easy you might have to add shims.
