MY 97 COBRA OUT OF THE BLUE STARTED BREAKING UP AT 5800 RPMS.WHAT WOULD CAUSE THIS I HAVE CHECKED MOST OF THE THINGS .CHANGED ALL KIND OF SENSORS COILS PLEASE HELP
mine has a check engine light too for a lean condition on bank two > I was going to change the o2 and see if that fixed it > I haven't checked the intake gasket yet> I still drive it everyday.
does anyone know how to check for intake leak?besides spraying carb cleaner around tried that nothing happened.also wouldnt you notice a leak by watching my boost gauge got great vacuum at idle 22lbs no fluctuations.any more ideas would be appreciated car still breaks up at 5800 rpms unless i gap my plugs down but that doesnt explain whats really wrong because when i installed the blower all was great for 6 moths then started to break up at 5800[/QUOTE ANYONE ELSE
hello
Stock injectors? Changed your fuel filter? Cleaned the IAC?
How old are the coil packs? When did you last change wires?
When did you last have it tuned?
new injectors last summer, new coil packs ,new fuel filter. wires were done last summer same with tune sept tune done on dyno
