Help me PASS Emissions!!!
  • Thread starter Thread starter Scorcher2005
  • Start date Start date Nov 7, 2005
Scorcher2005
883
South Carolina
Nov 7, 2005
  • Nov 7, 2005
before i left from boot camp i finished my engine combo in the sig (except for the fuel pump, so its stock). I now need to get emission tested. I've done it twice now, which were obviously both failures. The only part I'm failing is the Hydrocarbons. The first time was like a 2.5 on a .8 limit. I then thought i should put in lower grade gasoline (which burns easier) and lowered my timing from 12ish to 10ish to compensate. I then lowered my fuel pressure from 42psi w/o vac to around 20 w/o vac. I thought if i had less fuel to burn, i wouldnt have any hydrocarbons. Well i was wrong seeing how i now just tested a 4.5. So should i now do the opposite of my theory and up the pressure and timing? Any suggestions here? By the way, before i built my motor, it passed w/ flying colors.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 7, 2005
  • Nov 7, 2005
High HC is usually the result of no cats/bad cats and no working smog pump.
How to pass emissions testing:
1.) Make sure all the emissions gear the car was made with is present and connected up properly. That includes a working smog pump and cats.
2.) Make sure that you have fresh tune up with spark plugs, plug wires, cap, rotor, fuel & air filters. An oil & filter change is a good idea while you are at it.
3.) Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/article...c-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/det...iption.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
4.) Post the codes and get help to fix them. Don’t try to pass with codes not fixed. Clearing the computer just temporarily removes them from memory, it doesn’t fix the problem that caused the code to be set.
5.) Be sure to do the testing on a hot engine. Drive for 15-20 minutes prior to taking the test to get operating temps up into the normal range. Do not shut off the engine while waiting for your turn on the test machine. An engine up to full operating temperature puts out fewer emissions.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Nov 7, 2005
  • Nov 7, 2005
I've been doing a lot of research on acetone to help increase gas mileage and such. Accoring to this website it's also supposed to reduce hydrocarbons by 60%. Take a look under "additional benefits"
http://www.pureenergysystems.com/news/2005/03/17/6900069_Acetone/
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
  • dan50
  • Jul 18, 2026
dan50
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
