  • SN95 4.6L Mustang Tech
Help me Tune up my car!
  • Thread starter Thread starter Twista
  • Start date Start date Dec 17, 2006
Twista
510
@ the z00 in chicago
Dec 17, 2006
  • Dec 17, 2006
Guys, i need some help tuning up my car. I have a stock GT with alot of old STOCK ****. I know i have to change my plugs for a nice tune up, but what else do i need to do?
Can you please link me to some good, but cheap spark plugs and wires for a stock 96-98 GT and whatever else is needed.
Already Done: Fuel Filter is new and oil. What else do i need done???
Also, my car is making a sheeching sound from under the hood. Alot of cars have this sound it seems.. its almost like a supercharger whistle, but i think its a worn belt. Which belt is common for making this noise on cars?
Thanks!
twogts4us
4,188
12
79
Dunedin, FL
Dec 17, 2006
  • Dec 17, 2006
Thanks!
Check the www.bullittarchive.com - they have a maintenance section that has some good detailed instructions on the basics (including chging the plugs - this is an excellent article!!! Highly recommended)
Unless I missed something, it's just a single belt. See if you can quiet it down with 'belt dressing', available at any auto parts store. If that helps, it tells you it is the belt and you'll need to replace sooner or later.
sgarlic
3,085
Dec 18, 2006
  • Dec 18, 2006
How many miles are on the car? You could back flush and refill the antifreeze (add Redline water wetter too,) replace the thermostat, drain and refill the rear end fluid, drain and refill the trans fluid, remove and clean the mass air sensor with qd electrical contact cleaner, run Seafoam, lube any chassis grease fittings if there are any, replace the PCV valve, grease up the doors, seat tracks, hood hinge, trunk hinge, and heck I don't know how many other things. You could go further, replace upper and lower rad hoses.
Beltwise, just replace the belt. If that doesn't cure the squealing, verify that your alternator is in good shape, and verify that the tensioner is operating properly. Replace if necessary.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 18, 2006
  • Dec 18, 2006
The screeching is probably the tensioner or idler pulley. Mine is doing the same thing.
twogts4us
4,188
12
79
Dunedin, FL
Dec 18, 2006
  • Dec 18, 2006
sgarlic said:
You could back flush and refill the antifreeze (add Redline water wetter too)
Not sure he'd want to do water wetter - note he's in Chi-Town...and it's winter!
You qualified that statement well, 'cause, bro, there ain't none! (unless someone installed aftermarket LCAs or ???)
the98stang
2,408
Clovis, CA
Dec 18, 2006
  • Dec 18, 2006
Thanks!
The screeching sound is most likely a slipping belt.
You should also replace:
Coolant
T-stat
Tranny fluid (ESPECIALLY if auto)
rear end fluid
PS fluid
Check/ replace brake pads & flush fluid
PCV
IAC
Check A/C for recharge
That's a good start
sgarlic
3,085
Dec 18, 2006
  • Dec 18, 2006
Well, I wouldn't let that keep me from wanting cooler water temps. Since he likely won't need to change the coolant again for 20kish miles, chances are it'll see at least one hot summer after this winter.. right?
About the grease fittings, I was thinking the pre 99's had a few. Guess I'm drunk.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
