I'm having problems with setting the right parameters in my microsquirt for my setup. When attempting to turn the car over it does not want to fire. I have checked the first cylinder TDC in relation to the distributor rotor and that is good. I have had a buddy turn the distributor while I cranked the engine but nothing. We tested for spark and that checks out. It does smell rich from the 80lb injectors dumping all that fuel in the engine with none burning. I know the base tune would typically work for a 302 and 351. My motor is 460 cu in with 80lb Siemen Deka high impedance injectors. I'm knew to tuning and have done some reading and watched videos and even went the route of asking chatgpt to help determine some settings and areas I need to look into. Would someone more knowledgeable take a look at my file to see if there are any mistakes or areas I have not checked out? I have not attempted to create a log since I haven't been able to even get it running rough.
