I have an 89 mustang 5.0. The problem I have is that sometimes when I go to start the car it will start and then quickly die like the ignition looses power. Now there is a ticking sound coming from the dash that sounds like the turn signal noise but it's a slightly different sound and the dash lights come on and off. Possibly a relay turning on and off. I thought it was most likely a bad ground so I replaced the negative cable. And checked the ground that went to the inner fender, but this did not help.
