HELP new 347 smoking
curtisimo81
33
pensacola,fl
hey i just built a 347 stroker motor, i have keith black forged pistons hawks racing nodular iron crank, i beam connecting rods, molly rings, gt 40p heads with 1.90 intake and 1.65 exhaust valvs. ok just a brief discription of my motor not for the problem, after my motor warms up 10-15 mins it starts smoking a whitish bluish smoke, smells like oil burning, did a compression test and i have about 145-150lbs in all 8 cycl. any ideas on what would cause this problem, with having great comp. and it taking about 15 mins to start smoking its got me fooled any help or isight will be greatly appreiciated.
Thanks Curtis
perhaps a little blow by and it takes 10 min to pressurize the crank area? any chance a oil ring not installed or is stuck and not cleaning cylinders? have you checked behind the TB to see if you are putting excessive amounts of oil into the intake? via the pvc.
I've always heard you're supposed to run regular oil and take it easy for the couple hundred miles if not 1,000. There would be normal smoke from exhaust because it will take time for the rings to set, but then you switch to synthetic. There shouldn't be a problem after that if it sets right, and if you didn't beat on it during the break in period. That's what I've always thought.
Sorry it took so long to get back, went out of town for a few weeks, I haven't run the motor over about 3g, as far as the break in i dont have a 100 miles on the motor. I'm affraid to mess it up any more than it already is, had a few peep tell me they think its gas, not really sure though, changed the holley to and edlebrock to eliminate blown power valve, still smoking. the main thing thats got me stumped the engine ran for about an 1hour right after i put it in and no smoke, was running rich, so my boss tried tuing the carb some, it started smoking, and hasn;t stopped since. please and input will help
a wet/dry compression test will rule out alot...i sent you a pm you never replied if the heads were rebuilt with new valve guides but i would run the wet/dry compression test this will tell you if it is the valve guides. if you do post results and read link below for info. on running a wet/dry compression test and also if you don't have a compression tester wal mart sells them for about $20....
http://www.pumaracing.co.uk/comp.htm
