  • SN95 4.6L Mustang Tech
Help! P0174 :(
  • Thread starter Thread starter MY 04 GT
  • Start date Start date Jun 11, 2010
M
MY 04 GT
  • Jun 11, 2010
Ok, well this is my first post on the forums. Sad to say this first post is about an issue that my car is enduring.
I have a short ram intake from american muscle. the 55 dollar one. There are no vacuum leaks. Nothing. I Installed the Intake, all is well. No check engine like. Drove the car for about a month and then got my pypes 409 OFF ROAD x pipe installed. I have MIL eliminators on the car. I still had a check engine light. I got a tune from BAMA at american muscle for my sct tuner to turn the cel off. It worked for about 30 miles and the light came on again. I scanned the codes and i got a p0174. running lean in bank 2... drivers side. if nothing happened during the intake install, then it must be the x pipe install right?
At the moment, the car still has the MIL eliminators plugged in on the rear 02 sensors. could this give me the code? or is this something that has to do with the front 02 sensors? Am I totaly off the money? please help me if you have any ideas of what could be throwing this p0174 check engine light code.
thanks for your time.
Shiroelex
There's nothing worse than aut
728
Westland, MI
Jun 11, 2010
  • Jun 11, 2010
I've still got my MIL eliminators spliced into my rear O2s, along with my custom Xcal3 tune with the rears disabled. I've never gotten a light for the rear oxygen sensors, even before the tune. If it were a problem with them, the code would read something like Oxygen Sensor Malfunction Bank 1 (or 2) Sensor 2. Either that, or Catalyst Efficiency Below Threshold.
For your lean code, I would try cleaning your MAF first, double check all of your vacuum connections, then try changing out the upstream oxygen sensor on that side. I'd even throw in a little bottle of Lucas fuel treatment, and some Seafoam through the intake.
I ended up with a lean code once when the hose that connected to the front of my plenum slipped off a bit (The one that runs to the passenger valve cover). My aftermarket plenum had a smaller sized barb fitting on it than the stock hose was, so I had to make an adapter for it.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 11, 2010
  • Jun 11, 2010
Check the EGR tube for exhaust leaks. Also check the vacuum lines to/from the EGR DPFE sensor. These are hard to see because they are so close to the firewall. The exhaust gas will make them hard and brittle.
Any air entering via an exhaust leak will make the O2 sensor THINK it is lean.
OBTW, the P0174 is associated with the Front O2 sensor. The MIL's are for the rear's.
FEARNO1
1,241
Maine
Jun 11, 2010
  • Jun 11, 2010
I had that same code and my problem was an exhaust leak at the manifold x-pipe connection. Fixed the leak and the code went away
M
MY 04 GT
  • Jun 11, 2010
okay thanks! and i know i was just saying that the mils were on the rear because i thought i may make a difference.
thanks for all the help guys!
nyuk98gt
1,427
Chesterfield, MO
Jun 11, 2010
  • Jun 11, 2010
MY 04 GT:
"FEARNO1" nailed it: a leak (even a tiny one) is going to allow air in and the extra O2 is going to make the PCM think the engine is running lean.
Loosen the joints on the intermediate pipe (don't take the bolts out, just get them loose so that the pipe can be adjusted). Put a floor jack under the pipe and get the pipe nice and level with the bottom of the car. Snug up the joints: tighten one side a bit, then the other so that the joint is pulled together evenly. When you are torquing the bolts to spec, keep going side-to-side until the desired torque is achieved. Do the front joints first and then the catback/intermediate pipe joints.
If you want to use copper (O2-friendly), high temperature RTV on each joint, you can use it with confidence. It is not essential but it's an option. You would have to disconnect the o/r pipe completely so you can put a nice bead of RTV where it needs to go.
HTH,
Chris
p.s.--Welcome to StangNet!
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
squeak93
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
