Help Please!!!
  • Thread starter Thread starter bad2th3bone86
  • Start date Start date Feb 7, 2007
bad2th3bone86
23
  • Feb 7, 2007
I go outside and turn on the stang cause i have it off the road so i try and trun it on everyday for a little bit. It starts right up and then all of a sudden shuts off on me. When i turn the key i can hear the fuel pump turn on and i go to crank it on and the motor just rotates. It won't fire up for me!!! Any ideas?
Nitrox13
FL
Feb 7, 2007
  • Feb 7, 2007
Have you checked if you have gas?
C
CONCRETEWARFARE
208
NEW YORK
Feb 7, 2007
  • Feb 7, 2007
maybe the module on the distributor went. Check the coil wire.
Silvers
51
  • Feb 7, 2007
It aint got no gas in it mmmm hmmm (slingblade)
bad2th3bone86
23
  • Feb 7, 2007
it has a little more than a 1/4 tank of gas.... God this is such a pain in my arse!!
bz393
29
maryland
Feb 7, 2007
  • Feb 7, 2007
Check to see if you have spark and fuel pressure.
bad2th3bone86
23
  • Feb 7, 2007
i know this may seem really stupid but than again this is my first car and i am just learning...
How do i go about checking to see if there is spark and how do i check fuel pressure?
HISSIN50
34
129
Feb 7, 2007
  • Feb 7, 2007
See Jrichker's 'Cranks ok but no start checklist'. Don't screw around doing anything else till you print the list out. It will tell you how to systematically test the systems so you don't chase your tail.
Good luck.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
H
Engine 1992 mustang LX starting issue
  • Hdbandit
  • May 25, 2025
Fox 5.0 Mustang Tech May 25, 2025
General karthief
