HELP PLEASE
Check the Green bolt right there at the battery..... check the ground strap at both the block and the other end at the fenderwell.. Are both cables in good shape?
+1 i said check the ground cuase i had the same problem with my car and it was the ground on the core support that was bad.....
easy way to check is to jump it, but instead of putting the negative jumper cable on the negative battery post, put in on a metal part of the motor
Here's one...follow your Neg cable back to the block...this one connects there.
You have the Green bolt ground right at your battery as well.
Mine had both clicking or occasional no starts..I traced it to that ground arcing on the fender...Swapped it for a new one and problem solved...
Yours was working without that ground completely...don't know what to say on that one???
