Help power door locks stuck
  • Thread starter Thread starter gatorsteve
  • Start date Start date May 20, 2010
G
gatorsteve
  • May 20, 2010
88 mustang - cleaned the contacts on my door lock switch this weekend, tested them several times they seemed to work fine, locked the car and when I returned the key would not unlock either door. Since my car is a convertble I was able to unlatch the top and reach my hand inside the car and tryed to open doors with door switch and door handle, no luck, removed switches from door still will not open. Both doors stuck in locked position and cannot open either door. Any suggestions?
Y
y0ukantride
36
Indianapolis
May 20, 2010
  • May 20, 2010
can you use needle nose pliers and pull up on the manual lock on top of door panel
G
gatorsteve
  • May 20, 2010
I tried that and the knob came off. The weird thing is that both doors are stuck. What are the odds that both acuators are stuck?
Y
y0ukantride
36
Indianapolis
May 21, 2010
  • May 21, 2010
If you can take your door panel off you can unhook the bar hooked on the silinoid and the key wont be so hard to turn and it should unlock the latch
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
Electrical 5.0 88 Foxbody Door Locks
  • 88VertFox
  • Aug 29, 2025
Fox 5.0 Mustang Tech Sep 2, 2025
Mustang5L5
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
1989 gt both doors wont lock or unlock help.
  • 1989 mustang gt
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 22, 2025
manicmechanic007
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
