I was driving my 2003 GT (no real mods) yesterday and everything was going good. Went around a corner at an intersection and the car started losing power until it wouldn't go anywhere. I have a fuel pressure gauge and it was down to a hair above 0 so obviously I was thinking fuel pump. It would restart and idle alright, but you couldn't get it to go anywhere which I would assume is due to the residual pressure in the line. It will not start and idle anymore though. The fuel tank is a little over a 1/4 tank so I am assuming that there is a little over a 1/4 tank of gas although you don't hear it sloshing around a whole lot when you move the rear of the car around. I checked the fuse in the fuse box behind the battery and it is fine. The switch in the trunk is good, the button is down.
Is there a relay that I could look to, or anything else for that matter?? I was told by Ford it was most likely the pump. Since I am going to do it myself anyway it isn't a big deal I just wanted to know if there was something easier to look at or test first.
Please give me some ideas...
