  • SN95 4.6L Mustang Tech
Help! Something Wrong!
  • Thread starter Thread starter silence
  • Start date Start date May 24, 2006
silence
21
Christopher Lake Sk
May 24, 2006
  • May 24, 2006
I just tuned my car to performance tuning with the superchips tuner, and drove it a few times and it worked great. Then I go to school, and I'm just driving and it turns off. I start it again, look under the hood, and it's idling really rough and at a very low rpm, almost stalling even though it's an auto.
So I tried to go home and had to travel very slowly, because if I pushed the gas, the rpm would rise then fall and almost stall. And now it won't turn over.
Someone told me there could be oils from the air filter on my mass air sensor, that's screwing things up......So I'm going to get some sensor-safe cleaner, but I don't know if htat is the problem. Could it be the fuel system?
Give Me TP
936
Republic of Texas
May 24, 2006
  • May 24, 2006
First restore your stock tune to the vehicle
DTNODYA
831
  • May 24, 2006
Then post an update of how it runs.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 24, 2006
  • May 24, 2006
Yeah, dirty MAF is not going to cause that much trouble. Plus you will not be able to get to it without a security torx bit.
Replace the stock tune.
silence
21
Christopher Lake Sk
May 24, 2006
  • May 24, 2006
I returned it to stock, and it still won't turn over..........Now I have the fear it is the fuel pump.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 24, 2006
  • May 24, 2006
Reset the PCM (disconnect battery for 15 minutes)
silence
21
Christopher Lake Sk
May 24, 2006
  • May 24, 2006
Okay I'm trying that.......
silence
21
Christopher Lake Sk
May 24, 2006
  • May 24, 2006
No dice.....
BUT, before I tried that I checked my fuel pump reset switch, and it was off, so I turned it back on, and still no start. And I checked the DTC's with the tuner, and it told me that the fuel pump drive module is offline....sooo would that mean that my fuel pump is broken?
silence
21
Christopher Lake Sk
May 24, 2006
  • May 24, 2006
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 24, 2006
#10
  • May 24, 2006
  • #10
sounds like the fuel pump is gone..
first turn the key from off to the pos. just before start. several times then go and depress the screader valve on the fuel rails and see if fuel squirts out. If it does not then you know you have a fuel issue.
from the way you describe it I think it's the pump itself.
DTNODYA
831
#11
  • May 25, 2006
  • #11
I'm just gonna say it ... Do you have any gas in your tank?
P
Pennywise2
Banned
May 16, 2006
1,379
#12
  • May 25, 2006
  • #12
+1 Sounds like your fuel pump is bad.This is a great
chance to upgrade your fuel pump to a bigger one.
silence
21
Christopher Lake Sk
May 25, 2006
#13
  • May 25, 2006
  • #13
hahaha Yes I have fuel....Well I got it towed into town so ford will have a looksie I guess.....I'm almost positive it's the pump.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
  • Gulftown980x
  • Jul 29, 2026
squeak93
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
