Ok, so i had a pretty bad exhaust leak. My car was running like shat. So i fixed that, cleaned my MAF. Reset the ECU(removed - battery terminal) And its still running like junk.
It idles really rough when the engines cold and warmed up. It stays at about the same RPM 600-700 but shakes the whole car when it idles. When i rev it. It sounds like its running on 6 cylinders. When i drive it around it bucks and stumbles all over itself. After i drive it for about 15 minutes its seems to get a little better. Not missing as much, but still does. It seems like its getting worse. Almost to the point were i cant drive it. Its almost as if its getting to much or not enough fuel. Maybe something with the spark??? I did plugs, wires, cap and blaster coil not to long ago.....
i cant figure this one out....help
