Help, Tired of replace header gaskets!
  • Thread starter Thread starter jef0509
  • Start date Start date Sep 4, 2005
J
jef0509
83
New Jersey
Sep 4, 2005
  • Sep 4, 2005
I have seen the threads in the past so I know many people have problems with header bolts backing out. I have tried to recommendations but I still can't seem to get them to stay on.
I have the BBK shorties. I even tried the locking header bolts, but the ones I got from Jegs miss the exhaust tube and backout anyway (One backed all the way out and is missing). I made sure I had an even 25ft/lb on the bolts. I tried tightening them after a hundred miles (it's a PITA to do it so often). I have been using Mr. Gasket, but I am switching to Fel-pro this time. I have some one inch bolts I am going to use. Any other recommendations? I've swapped these out three times already and I keep getting leaks!
Thanks in advance.
Jeff
BTW its a 91GT with BBK shorties, BBK catted X, and flowmasters
RYC CUKR
1,437
Orlando
Sep 4, 2005
  • Sep 4, 2005
I have used Stage 8 locking header bolts. Never had problem with them backing out. They can be a little tricky to put on but once on they should fix your prob
88gt
794
Drillers cabin
Sep 4, 2005
  • Sep 4, 2005
I use a small dab of red high temp silicone on the bolts. Since you're going to be there anyways, might as well give it a shot.
Good Luck...
Jim
maverick0716
3,924
Chilliwack, BC, Canada
Sep 4, 2005
  • Sep 4, 2005
I don't use locking header bolts and I've never had a problem with them backing out. What I did when I installed them was check them often for the first month or so. Yes, they would move a bit, but just keep checking them until they don't move anymore. Usually the people who have problems don't ever check the bolts for tightness until they lose a bolt or have an exhaust leak.
D
Daggar
3,902
  • Sep 4, 2005
www.stage8.com
legalize420
1,541
South Florida
Sep 4, 2005
  • Sep 4, 2005
i checked mine eveyday for the first week after. get some gloves and get in there and tighten them while still hot. maybe get some lock washers.
shifterpilot5.0
49
  • Sep 4, 2005
I used the stock header gaskets from felpro. Never even backed out! Mabe it was luck
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Sep 4, 2005
  • Sep 4, 2005
I've always used Loc-tite. The stock header bolts are installed with loc-tite on them from the factory.... this is the reason the stock header bolts don't back out and leak...(for many many miles... My headers have never been off in 15 years, and 100K+ miles.. and I have 0 leaks) Good luck.
J
jef0509
83
New Jersey
Sep 4, 2005
  • Sep 4, 2005
Thanks for the help, I'll try some loctite and keep checking them.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Sep 4, 2005
#10
  • Sep 4, 2005
  • #10
The main reason for header bolts backing out is because of crappy header flange quality. If the flange has the slightest amount of warpage to it every bolt isn't going to have the same amount of torque and, in turn, they will back out. I had problems with my MAC headers with bolts backing out. I bought a pair of Bassani headers and never had to re-tighten them again after one heat cycle. A good pair of headers will save you many headaches down the road.
Dbeck002
710
South florida
Sep 5, 2005
#11
  • Sep 5, 2005
  • #11
Do felpro header gaskets have a UP side or DOWN side? Because i installed a set during the build and just making sure they are reversible.
legalize420
1,541
South Florida
Sep 5, 2005
#12
  • Sep 5, 2005
  • #12
not UP and DOWN, it has a HEAD side. i could be wrong but i dont think they are reversible. if they are reversible it would not say head side.
04sleeper
2,674
14
89
Dallas, TX
Sep 5, 2005
#13
  • Sep 5, 2005
  • #13
Try some Felpro 1415's, they have always worked well for me.
W
WhiteHeat306
283
Philadelphia Suburbs
Sep 5, 2005
#14
  • Sep 5, 2005
  • #14
I use ARP header bolts with lock washers on them, along with a little dab of Loctite on each bolt for added insurance. No leaks since then.
Dbeck002
710
South florida
Sep 5, 2005
#15
  • Sep 5, 2005
  • #15
Mine did not say Head side or Header side. So i just put them in however. They seem to work.
legalize420
1,541
South Florida
Sep 5, 2005
#16
  • Sep 5, 2005
  • #16
what kind of gasket? if it worked then its all good. im just going by what i saw when i did the gasket swap a few weeks ago. 1415's say head side.
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
