Help to get my power steering to not leak!
On my 1970 Mustang(351W) I just replaced all of my power steering components since for the last year I had only manual steering on the car. Now with all of the new(rebuilt by a competent shop) components put back on the car, I still have some very small leaks. The two lines that go into the slave cylinder have very small leaks around the fittings, and the line into the back of the pump has a very small leak. This is going to drive me insane! The lines are new (replaced before I removed the system last year in an attempt to get rid of the leaking). Are there any upgraded lines on the market? I've searched this site for the last two hours and can't find what I'm looking for. Any help would be appreciated!
Haha yeah I've had the same problem! But I'm still looking for a fix for it. I'm told if the lines are put in just right that they won't leak. Is there any better which way to attatch the return line to the pump other than just a regular ol' hose clamp?
I used a thicker(wider) clamp and that seemd to fix the leak up top, but then it leaked somewhere else.:shrug:
I had to use teflon tape around all my fittings when I ran P/S. Then again, I got use to the old saying, if it ain't leaking, it ain't working.
Not a real good leak solution as the sealing on the flare fittings is between the flare on the tube and the seat in places like the control valve and slave cylinder. If tightened too much, the seats can be scored and this will cause leaks. The seats are aluminum and are replaceable.
