  • SN95 4.6L Mustang Tech
help w/code after tune
  • Thread starter Thread starter bgrd351
  • Start date Start date Jun 25, 2006
bgrd351
109
Jacksonville, Fl
Jun 25, 2006
  • Jun 25, 2006
I just got my car tuned on a dyno yesterday and went out to see if any codes had appeared and found this:
P1474 Low Fan Control Primary circuit
does anyone know what this means and what is causing it?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jun 25, 2006
  • Jun 25, 2006
that code might have happend durring programing. I woukld clear this code and see if it comes back in a few days.
P1474 - Low Fan Control (LFC) Primary Circuit Failure Monitors the low fan control (LFC) (fan control [FC] for one speed fan application) primary circuit output from the PCM. The test fails if: When the PCM grounds the LFC/FC circuit, excessive current draw is detected on the LFC/FC circuit; or with the LFC/FC circuit not grounded by the PCM, voltage is not detected on the LFC/FC circuit (the PCM expects to detect VPWR voltage coming through the low speed FC relay [or CCRM] coil to the LFC/FC circuit). Open or shorted LFC/FC circuit
Open VPWR circuit to low speed FC relay
Damaged low speed FC relay (or CCRM)
Damaged PCM
When the LFCF PID reads YES, a fault is currently present
An open circuit or short to ground can only be detected when the PCM is not grounding the LFC/FC circuit
A short to power can only be detected when the PCM is grounding the LFC/FC circuit.
During KOEO and KOER Self-Test, the LFC/FC circuit will be cycled on and off
the most common causes of this code is a bad CCRM or short to power.
bgrd351
109
Jacksonville, Fl
Jun 29, 2006
  • Jun 29, 2006
sorry for the slow reply to you but I got slammed at work the last few days but here is the update: I can clear it and it comes right back after a few minutes of driving. I called the tuner and he says he needs to adjust a switch in the tune.
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
