Help! Water coming into the rear seat foot-well
Dave Higgins
UK
Hi,
I have water coming into my 2005 Mustang behind the drivers seat in the rear passengers foot-well after it has rained. This only seems to happen if parked on an incline.
I can only assume its somehow coming through the door but cant see from where?
I know its not from the front as I cured that problem by unblocking the water drains in the scuttle under the pollen/cabin filter and replacing the filter. the filter housing was full to the top with water prior to draining it, That cured the water into the front passengers foot-well and no problems there since.
Its just the rear leak that has me stumped.
If I had to guess probably your window seal, did you check that?
Hi I looked at the seals and the rubber looks a bit dry and when gently pushed it easily breaks away from the glass, I guess that is why it only appears to come in when the rain drives from a certain direction, Many thanks, I will keep an eye on that and investigate it further.
