  • SN95 4.6L Mustang Tech
help what is wrong with my car
  • Thread starter Thread starter jake91
  • Start date Start date Jun 4, 2009
J
jake91
  • Jun 4, 2009
okay well its my dads car, but anyways what could be wrong. the car is a 98 gt and it wont run. it starts and dies after a couple seconds unless you give it gas, but then it dies once you let off, and it smell like its running rich.
J
jlds91389
241
Orange Tx
Jun 4, 2009
  • Jun 4, 2009
maybe a plug?
jeremy canter
402
Orange County , NY
Jun 5, 2009
  • Jun 5, 2009
sound like you have a really bad vaccum leak or you mass air sensor is bad>
G
GDTrumbo
199
Nashville, TN
Jun 5, 2009
  • Jun 5, 2009
Throwing codes? Dirty IAC valve, or as jeremy said. MAF sensor down.
GT
Spreadman
two wheels
Houston, TX
Jun 5, 2009
  • Jun 5, 2009
Bad idle air control motor. Buy a new one.
J
jake91
  • Jun 5, 2009
i will let my dad know these things when he gets off work. also i dont know if it matters but the car only has 58k miles
M
My2003Mach1
25
Torrington, CT
Jun 5, 2009
  • Jun 5, 2009
I'd agree, It sounds like the MAF, i had a similar issue when i started my stang for the first time after rebuild. I forgot to secure the MAF and it separated from the cold air intake tubing causing the car to start and stall.
J
jake91
  • Jun 6, 2009
okay an update. its kind of odd though. my dad started the car today and held the gas to keep it running, and after around 7 minutes he herd a pop from the engine, and the car started running normal
Spreadman
two wheels
Houston, TX
Jun 6, 2009
  • Jun 6, 2009
I still say IAC. Mine did the same thing.
A
agentl074
#10
  • Jun 6, 2009
  • #10
Could be both I would spray out the MAS with some meter cleaner and see if that does it; if not, take her in to get the IAC looked at. They can also check the lines and make sure you don't have a leak somewhere.
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Surging/stalling! problem or tune?
  • djj62478
  • Sunday at 1:53 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 11:37 PM
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
