Help! What's wrong?
  • Thread starter Thread starter gtcoupeaust
  • Start date Start date Jan 6, 2006
gtcoupeaust
9
  • Jan 6, 2006
After swaping the intake. Tb, inj, Maf, I attempted to start the car and it feels and sounds like the engine is binding up.. Like a compression lock.. i can manually turn the engine over a full revoloution.. if i remove the distributor cap it still wont crank once. as i forgot to drain the radiator could water have entered the head and caused compression lock? i am yet to remove the plugs. But why can i turn the engine by hand.
the crank is short and louder and makes the car jolt slightly. It is not a hard lock up but definitely different to before. Is there something i am missing?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 6, 2006
  • Jan 6, 2006
Pull the plugs anf crank the engine. If you find water, plan on changing the oil. If you don't find water, you may have a bad or missing ground.
1.) The main power ground is from engine block to battery: it is the power ground for the starter & alternator.
2.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects.
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
  • dan50
  • Jul 18, 2026
dan50
