  • 2005 - 2009 Specific Tech
Help with a trouble code
  • Thread starter Thread starter firemanken
  • Start date Start date Jun 29, 2008
F
firemanken
46
  • Jun 29, 2008
the check engine light came this afternoon. i checked the code and it's P0456. Anyone have any ideas what it is?
the car is running fine and the gauges look normal. I just filled it up with gas this morning so i thought it might have been a gas cap issue. I tightened it then I took it off completely and put it back on. I was hoping that was the issue.
Thanks for your help
NastyStang113
1,567
Florida
Jun 29, 2008
  • Jun 29, 2008
Yes, it's a small evap leak. Most commonly the gas cap is loose. I just had to fix my girl's car. I just tightened the gas cap, cleared the code, and it hasn't come back since.
F
firemanken
46
  • Jun 29, 2008
thanks. i'll clear the code. I just wanted to make sure it wasn't anything serious before i cleared it.
G
goldy50
  • Jul 23, 2008
DTC code 455
I too have just got a code 455 on my 2006 Saleen , it shows Evap control system gross leak. I have re-set the code but am concerned about where how this leak would have occurred. Any thoughts and where should I look?
frdfrst
178
phoenix az
Jul 28, 2008
  • Jul 28, 2008
check seal around top of gas tank.remove rear seat and see if there is any dust stuck to the seals.that was my problem.tightened and fine.
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Aug 4, 2008
  • Aug 4, 2008
a "very small leak" DTC is normally a vac. line or vent tube leak. if its a "gross leak" then its a gas cap
like stated before check the cap seal for debris or dirt. also you may need a new cap of it leaks.
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
F
Help with air bag code 2293
  • Felwinters
  • Apr 23, 2026
2005 - 2009 Specific Tech Apr 23, 2026
Felwinters
F
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
