help with bad Negitive camber
  • Thread starter Thread starter Mongo316
  • Start date Start date Mar 31, 2007
Mongo316
43
Hamilton ontario
Mar 31, 2007
  • Mar 31, 2007
Hello All its spring and in canada its warming up finally... I took the 1967 stang out of storage and did my routine check and noticed bad bal joints (lower).
I replace my lower control arms and also upgraded to a 1 inch sway up front.
I placed the car down and noticed my wheels are pigion toed (i think its alot of negative camber). How do I adust this - camber at least to have it driveable to the shop. Uppers were not touched as the ball joints where done last year.
I have read other forms but cant find any info on how to adjust this
Any help would be great
thanks Mario
Mongo316
43
Hamilton ontario
Mar 31, 2007
  • Mar 31, 2007
lower control arm eccentrics is this what I installed wrong? is there a way to set this differently?
2bav8
2,511
Mesa, AZ
Apr 1, 2007
  • Apr 1, 2007
Have you moved the car yet? The suspension might not have settled after being in the car so long.
Also, are the tires tilted in at the top, or are the front of the tires closer to each other than the rears are? Just trying to see if the toe was off instead of the camber.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Apr 1, 2007
  • Apr 1, 2007
Yep, move the car around a little before trying any adjustments--it will probably change for the better.
Mongo316
43
Hamilton ontario
Apr 1, 2007
  • Apr 1, 2007
The tires look like this
/ / \ \ so i think the lower LCA is pushing the bottom of the sindle out alittle to far.
I drove the car up the road and no change its hard to drive special when turning...
thanks for the reply so far
S-Car-Go
332
San Jose, CA
Apr 1, 2007
  • Apr 1, 2007
Loosen the nut on the inside bolt of the lower arm, then use a socket to twist the bolt. The oblong washer will force the pivot point towards the center of the car. Half way of the adjustment is a good starting point. Sounds like you have it adjusted to the far outside.
Mongo316
43
Hamilton ontario
Apr 2, 2007
  • Apr 2, 2007
Thanks to all for your help! It all makes sence i have also attached a linky from an article i have found. I think I am ok to attach this right?
http://www.mustangandfords.com/techarticles/35998_front_end_alignment/
Thanks Mario
1966conv
220
  • Apr 2, 2007
From his description, I think 2bav8 is correct, he has a toe in issue not a camber issue. I think the solution is a combination of tie rod/strut rod adjustment.
Mongo316
43
Hamilton ontario
Apr 2, 2007
  • Apr 2, 2007
How do I adjust the toe issue that I have? Is done with the tie rods or the strut rod adjustments.
I seem to have feathering on the midle to inside of the tires. I am going to take a mesurment from the front of the tire and the rear and compare and see how far I am out. but i need to know how to adjust
thanks again
Mario
H
Helmantel
206
#10
  • Apr 3, 2007
  • #10
Just to make sure:
Does // \\ mean that the tires look like that when viewing the car from the front (too much negative camber) or from above (too much toe in) ?
Negative camber is adjusted by turning the LCA-to-chassis bolt and excentric and toe by turning the tie rod adjustment sleeves.
If both are off, then first set the camber untill the wheels are perpendicular to the pavement and then continue with adjusting the tie rods so that wheels point straight ahead. Of course, that will not result in an accurate alignment, but you can actually get it reasonable close (if you're not severely cross eyed )
Close enough to drive it to the alignment shop anyway.
Mongo316
43
Hamilton ontario
Apr 3, 2007
#11
  • Apr 3, 2007
  • #11
Just to make sure:
Does // \\ mean that the tires look like that when viewing the car from the front (too much negative camber) or from above (too much toe in) ? This was the look from me looking at the car from the front.
Negative camber is adjusted by turning the LCA-to-chassis bolt and excentric and toe by turning the tie rod adjustment sleeves. I have since adjusted my camber.
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
