  • 1994 - 1995 Specific Tech
help with bolt sizes.....
  • Thread starter Thread starter Green 94 5.0
  • Start date Start date Apr 8, 2006
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Apr 8, 2006
  • Apr 8, 2006
does anyone know the correct bolt size, thread, etc. for the bolts that would hold the motor to an engine stand? also, does anyone have the same info for the accessory bracket bolts? thanks in advance.
P
Purple95
  • Apr 8, 2006
I'm not quite sure of the exact size and thread of the bolts for the engine stand but I used the bolts that mount the tranny to the engine on mine and the were a perfect fit. I don't have a clue on what bolts to use on the bracket.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 8, 2006
  • Apr 8, 2006
You can use old head bolts to bolt it to the stand, you'll just need some washers to space the bolt out a bit as a head bolt is a little too long.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Apr 8, 2006
  • Apr 8, 2006
perfect. now to see if i have any old ones laying around. thanks for the help. now if i could just get the pilot bearing out, i would have it made.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Apr 8, 2006
  • Apr 8, 2006
the problem is, all that stuff is still in the car and i need the crate motor on the stand. my only option at this point is to buy new hardware.
legalize420
1,541
South Florida
Apr 8, 2006
  • Apr 8, 2006
7/16 coarse. the ones i have are 2.5 inch. measure the stand just to be sure of the lenght. my friend needed longer bolts on his stand. i actually just picked up a short block and bolted it up to a stand this morning.
legalize420
1,541
South Florida
Apr 8, 2006
  • Apr 8, 2006
i got the grade 8 bolts from ace for a buck each
legalize420
1,541
South Florida
Apr 8, 2006
  • Apr 8, 2006
btw, home depot by me did not have them. pick up some washers also if you dont have.
mytight95
2,605
Dothan,Al
Apr 8, 2006
  • Apr 8, 2006
there is another thread where we listed the bracket bolt sizes...... somewhere... i can't remember them right now though
jason
Black95GTS
1,644
Marlborough, MA
Apr 8, 2006
#10
  • Apr 8, 2006
  • #10
I've been down the pilot bearing road before. The whole trick is to use hydraulic pressure. Take a bar of soap and jam in as much as you can till you can't any more. Then take something that fits in the hole, and hammer that soap in as much as possible. Repeat, putting more and more soap shavings through the pilot bearing until you can't fit any more back there. THen keep hammering the soap in farther.
What will happen is that the soap will put so much pressure on the backside of the pilot bearing as you compress the soap that it will be forced out.
Spent about 45 minutes with a slide hammer before Google showed me the light. Took about 2/3 a bar of soap.
Adam
mytight95
2,605
Dothan,Al
Apr 8, 2006
#11
  • Apr 8, 2006
  • #11
i have never had that much trouble with a slide hammer, did you keep it level, two toothed puller or three, a three disperses the pressure better for equal force.
jason
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Apr 8, 2006
#12
  • Apr 8, 2006
  • #12
Adam
my pilot bearing problem isnt that simple. it is an eagle crank and the bearing is snug against the inside of the crank. there is no space to use a bearing remover, slide hammer, or hydraulic pressure. the only soace behind the bearing is the 2 notches on the back to let you use a puller. i am in the process of grinding the jaws down on the puller i have to get it to grab the back of the bearing. talk about a royal PITA.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Apr 8, 2006
#13
  • Apr 8, 2006
  • #13
ace hardware is the best. the one on johnson st. and university dr. has never let me down when i have been looking for grade 8 hardware.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Apr 9, 2006
#14
  • Apr 9, 2006
  • #14
And you got the pilot bearing out so its good news day.
95strokerPSU
986
Sacramento from Philly
Apr 9, 2006
#15
  • Apr 9, 2006
  • #15
Alternator Side:
(1) 3 5/8" length 3/8" thread
(1) 2 7/8" length 3/8" thread
(1) 2 5/8" length 7/16" thread
Power Steering Side:
(2) 3 3/8" length 7/16" thread
(1) 5 5/8" length 7/16"
I just got 12 point ARP bolts from www.totallystainless.com The only one they didn't have was the 5 5/8" but it's covered by the power steering pulley so I'll probably just reuse the stock bolt.
legalize420
1,541
South Florida
Apr 10, 2006
#16
  • Apr 10, 2006
  • #16
pics from yesterday
http://putfile.com/pic.php?pic=4/9822501138.jpg&s=x11
http://putfile.com/pic.php?pic=4/9822474225.jpg&s=x11
http://putfile.com/pic.php?pic=4/9822534410.jpg&s=x11
http://putfile.com/pic.php?pic=4/9822370860.jpg&s=x11
http://putfile.com/pic.php?pic=4/9822343641.jpg&s=x11
http://putfile.com/pic.php?pic=4/9822313225.jpg&s=x11
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
F
Putting 1991 Hatch on 1986 Car - What Size/Thread Hinge Bolts?
  • frwgt350net
  • Jun 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
Mcmahst
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
