  • SN95 4.6L Mustang Tech
Help with Brake light switch
  • Thread starter Thread starter pwcracer
  • Start date Start date Jul 21, 2004
pwcracer
347
Hastings, MN, USA
Jul 21, 2004
  • Jul 21, 2004
I may have posted this elsewhere, but my brake lights on my 94 are staying on, even after I disconnect the switch. I can't figure this one out, and this is my daily driver. I was hoping you guys had some ideas.. Do the lights come on when the circuit completes, or does the switch ground the circuit? I tried shorting the connector as a last resort, and still the lights were on.
I may have to bring it into the dealer $$$$
Black_Cobra
80
Boston,MA
Jul 21, 2004
  • Jul 21, 2004
Thats gotta suck. lol How do I explain? When you are not stepping on the pedal, the switch should be pushed in and the lights should be off. It's when you step on the pedal that the switch is not pushed in and this should cause the lights to come on. You either need to adjust the switch position such that it is depressed when you are not stepping on the pedal or replace the switch. Another thing to consider, sometimes they put a rubber or plastic bumber pad between the pedal and switch, if this little bumber falls off or breaks, then your brake lights will stay on. So, have you found any small pieces of rubber or plastic on your carpet lately? If this is your problem then you could just get a little adhesive rubber-bumper-type-thingie from Home Depot and stick it in there between the switch and the pedal.
I think you can figure it out. Don't go to the dealer.
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
O
1967 Manual Drum Brakes , replaced the master cylinder and the brake light switch but the brakes lights stay on.
  • OldNSloww
  • Jul 14, 2025
Classic Mustang Specific Tech Jul 16, 2025
horse sence
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
