Hi ScreaminMimi! Glad to see you're still workin' on it. There are a variety of C4's like there are apples. Do you have the tag off the driver's side servo cover? Anyway, if I remember correctly the gas pedal linkage is quite different between the 6 & 8 (needs to be replaced). The downshift rod is different. The shop manual has no dimension specs. for where things actuall sit, but I know the shifter itself is mounted on the tunnel and the rod to the tranny has about 3" worth of adjustment in it. Can you tell me (using a level maybe?) how far away from the firewall the back of the engine is? I can compare it with my I6 or maybe one of the others has a measurement for their V8? Sounds like you need the V8 shift rod, though.
