Help with compression tester
  • Thread starter Thread starter rei-04
  • Start date Start date Nov 19, 2004
R
rei-04
63
TX
Nov 19, 2004
  • Nov 19, 2004
I just bought this compression tester and it says on carburetor cars to tie a string to the carburetor throttle plates to keep them wide open, but I have fuel injected 5.0 and was wondering if I still have to do this? Also I am testing it without my upper manifold on, so that wouldn't matter anyways, right?? Any help would be great.
T
TheUser
1,859
Springfield, MO
Nov 19, 2004
  • Nov 19, 2004
i'm not sure how safe it is testing compression w/o the upper on. If you're fuel injected, all you should have to do is pull all of the plugs, insert the compression tester tightly into the desired cyclinder and crank until it stops increasing...I usually go 10 times or so.
R
rei-04
63
TX
Nov 19, 2004
  • Nov 19, 2004
thanks for the info. that is reasuring to hear I was hoping I didn't have to do that. I have to take my upper manifold off and install these 24# injectors that is why I asked if I could just test it while it was off.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
  • dan50
  • Jul 18, 2026
dan50
Engine 1994 5.0 refuses to idle
  • FordFanatic1894
  • Jul 20, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 22, 2025
General karthief
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
