Help With Drivers Door
  • Thread starter Thread starter KW's65
  • Start date Start date Jan 2, 2004
K
KW's65
  • Jan 2, 2004
Can anyone tell me how to replace the door latch pawl bushing. I have the part but dont know how to get the broken one out and the new on in. PLEASE HELP!!!
Is the a way to seperate the outer and inner door skins? I need to get into the latch and locking mechanisms. Way too small for a human hand to get into and change parts.
Pakrat
3,843
Currently: NH Originally: Rhode Island (and all po
Jan 2, 2004
  • Jan 2, 2004
Are you saying that you can not get to the mechanism from inside the car with the window up after removing the vinyl panel? I am confused how you know what was broken without gaining access first?
K
KW's65
  • Jan 2, 2004
I can see the broken part oncee the vinyl skin is removed, but cant get hand back inside there to remove it and insert the new pawl bushing.
Pakrat
3,843
Jan 2, 2004
  • Jan 2, 2004
Hmmmm. Well, I would not consider removing the outside skin at all for this typ of fix, it's best to just remove the whole lock and work on it utside of the door then. The lock should remove easily. Once you have taken out the two or three bolts from the outside of the jam, reach inside and unhook the three rods that connect the lock to the outer latch, inner latch and button at the top of the window. They are only held in place my a retaining clip. Just push the clip open at the ned of each rod and the whole lock assembly will come right out. Actually when it is just unbolted you may have enough play to fix it without disconeccting the rods. The clips are stubborn but removal is easy.
T
1990 Convertible door squeaking
  • Tom77
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Tom77
T
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
P
Fox Opinions Wanted- at a crossroad with my '88 GT
  • pindude80
  • Apr 18, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 22, 2025
pindude80
P
