help with e.g.r. valve.
fivespeedsteed
Oct 17, 2003
748
22
69
Richmond, VA
so i have gotten some gasket leaks that have just come up in the past 4 or 5 months. whnei got the car about a year ago it didnt leak any, now it does. it had 2000 miles put on it in 10 years, garage kept. i have 5 gaskets that are leaking, and i dont know if my head gaskets are ok. front seal, rear seal, and both valve covers and the oil pan. the oil pan gasket i can touch and it feels rubbery still and doesnt look like its in all the way, meaning it bulges out in a few places. the passenger side of the engine is beautiful but the drivers side isnt.
so someone told me my e.g.r. valve screen may be clogged and increasing my oil pressure in the crank case. my gauge runs about 3/4 the way up on the oil pressure, and gets down to about a 1/4 hot idle. where is the egr valve located? where is the screen? should i get a new valve, and screen? can this be the problem?
i think the gaskets are actually okay, becasue it didnt leak about 6 months ago, but now it does.
can someone post a pic of where it is in my engine bay? and how i can take the screen out and look at it?
there it be, not sure they have a screen but the little flapper will quite workin, not sure if it will cause to much crankcase pressure, it is vented through the pcv valve not the egr, someone will have better info
The EGR does not vent the crankcase. That is the job of the PCV valve. It is located behind and below the lower intake manifold. The recommended replacement interval is evey time you do a tuneup. The PCV valve is less than $5 at most auto parts stores.
The screen for the PCV valve is installed in the engine block and will sometimes clog. A pair of needle nose pliers or surigical forceps can be used to extract the screen once the rubber grommet the PCV sits in is removed. Do a search on screen and you will find more info.
fivespeedsteed said:
can i see a pic of where it is?
Not unless you are a snail and have an eyeball on a stalk!.:D
The PCV valve is buried below and behind the lower intake manifold at the back of the engine block. I have changed the PCV valve several times, but have only been able to see the screen when I had the upper intake manifold off or the engine out of the car.
Snikt89GT said:
Yes you can, it's easy. You can replace the PCV grommet, valve, and screen while the engine is in the car. Just have to reach around the back and tweak around some.
I did it today
Not hard to do, just hard to see real easily. If you have big hands, you may find it a bit tight.
