Help with fuel pump
serranimal
Well my fuel pump wasn't pumping any fuel so bought a new fuel pump. Installed the new pump and it still didn't work. So then bought a new fuel relay and it started to pump gas. Car started but continued to die. All of a sudden the harness that connects to the pump got really hot and melted the plastic. So turned the car off and checked the fuel relay and was also very hot. And now when I try to start it nothing is happening now. I do hear a click by the relay though. What are my other options?
Its a 1987 ford mustang 5.0. So I got the fuel pump to turn on but then shuts off within 2 sec. I hear the relay click then once it clicks again it shuts it off. I felt the wires leading into the relay and there pretty hot.
I'm an amateur but you may want to check your inertia switch & fusible links. Actually come to think of it the same exact thing happened to me years ago...it ended up being the ground inside the harness leading to the pump. I unraveled the tape on the wires from the factory and they had them pinched/bent then wrapped tightly with tape so it eventually fried the top connector to the fuel pump and ground wire (black inside that harness) was totally shorted. Just my two cents
I checked the inertia switch by bypassing it but was still getting the same problem. I did think of the fusible link but then thought if that was the problem then I wouldn't be getting any power right? I don't know. The harness was really bad so I just cut off the connector and rewired it to be direct. When I did that it fired right up. So I thought everything was good. So I put it all back together and I'm back to the same thing. So I don't what is causing the problem.
I would check for 12 volts using a voltmeter at the pump harness (take doesn't need to be out, just take some safety pins and penetrate the insulation) I found my bad ground by testing that harness every 6 inches or so until I found 12 volts. From there youll know what part of your ground is bad if it is...hope that helps
Fuel Pump Troubleshooting for 86-90 Mustangs
Revised 30-Aug-2008 to update fuel pump wiring diagram
Clue – listen for the fuel pump to prime when you first turn the ignition switch on.
It should run for 5-20 seconds and shut off. To trick the fuel pump into running,
find the ECC test connector and jump the connector in the upper RH corner to
ground.
attachment.php
If the fuse links are OK, you will have power to the pump. Check fuel pressure –
remove the cap from the Schrader valve behind the alternator and depress the
core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be
used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch
cars hide it under the plastic trim covering the driver's side taillight. Use the
voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most Mustangs built
before 92.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect
for fuel escaping while pump is running.
The electrical circuit for the fuel pump has two paths, a control path and a power
path.
The control path consists of the inertia switch, the computer, and the fuel pump
relay coil. It turns the fuel pump relay on or off under computer control. The
switched power (red wire) from the ECC relay goes to the inertia switch
(red/black wire) then from the inertia switch to the relay coil and then from the
relay coil to the computer (tan/ Lt green wire). The computer provides the ground
path to complete the circuit. This ground causes the relay coil to energize and
close the contacts for the power path. Keep in mind that you can have voltage
to all the right places, but the computer must provide a ground. If there is no
ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like
fuses, except they are pieces of wire and are made right into the wiring harness.
The feed wire from the fuse link (orange/ light blue wire) goes to the fuel pump
relay contacts. When the contacts close because the relay energizes, the power
flows through the contacts to the fuel pump (light pink/black wire). Notice that
pin 19 on the computer is the monitor to make sure the pump has power.
The fuel pump has a black wire that supplies the ground to complete the circuit.
Remember that the computer does not source any power to actuators, relays
or injectors, but provides the ground necessary to complete the circuit. That
means one side of the circuit will always be hot, and the other side will go to
ground or below 1 volt as the computer switches on that circuit.
attachment.php
Now that you have the theory of how it works, it’s time to go digging.
Look for 12 volts at the Orange/Lt. Blue wire (power source for fuel pump relay).
No voltage or low voltage, bad fuse link, bad wiring, bad ignition switch or ignition
switch wiring or connections. There is a mystery connector somewhere under the
driver’s side kick panel, between the fuel pump relay and the fuse link.
Turn on the key and jumper the fuel pump test connector to ground as previously
described. Look for 12 volts at the Light Pink/Black wire (relay controlled power
for the fuel pump). No voltage there means that the relay has failed, or there is a
broken wire in the relay control circuit.
Check the Red/black wire, it should have 12 volts. No 12 volts there, either the
inertia switch is open or has no power to it. Check both sides of the inertia
switch: there should be power on the Red wire and Red/Black wire. Power on the
Red wire and not on the Red/Black wire means the inertia switch is open.
Pump wiring: Anytime the ignition switch is in the Run position and the test
point is jumpered to ground, there should be at least 12 volts present on the
black/pink wire. With power off, check the pump ground: you should see less
than 1 ohm between the black wire and chassis ground.
attachment.php
The yellow wire is the fuel tank sender to the fuel quantity gage. The two black wires are grounds.
One ground is for the fuel tank sender and the other is the fuel pump. The ground for the fuel pump
may be larger gauge wire that the fuel tank sender ground wire.
Make sure that the power is off the circuit before making any resistance checks. If the circuit
is powered up, your resistance measurements will be inaccurate.
You should see less than 1 Ohm between the black wire(s) and ground. To get some idea of what
a good reading is, short the two meter leads together and observe the reading. It should only be
slightly higher when you measure the black wire to ground resistance.
The Tan/Lt Green wire provides a ground path for the relay power. With the test
connector jumpered to ground, there should be less than .75 volts. Use a test
lamp with one side connected to battery power and the other side to the
Tan/Lt Green wire. The test light should glow brightly. No glow and you have a
broken wire or bad connection between the test connector and the relay. To test
the wiring from the computer, remove the passenger side kick panel and
disconnect the computer connector. It has a 10 MM bolt that holds it in place.
With the test lamp connected to power, jumper pin 22 to ground and the test
lamp should glow. No glow and the wiring between the computer and the fuel
pump relay is bad.
Computer: If you got this far and everything else checked out good, the computer is suspect.
Remove the test jumper from the ECC test connector located under the hood.
Probe computer pin 22 with a safety pin and ground it to chassis. Make sure the computer
and everything else is connected. Turn the ignition switch to the Run position and observe
the fuel pressure. The pump should run at full pressure.
If it doesn't, the wiring between pin 22 on the computer and the fuel pump relay is bad.
If it does run at full pressure, the computer may have failed.
Keep in mind that the computer only runs the fuel pump for about 2-3 seconds when you turn
the key to the Run position. This can sometimes fool you into thinking the computer has died.
Connect one lead of the test light to power and the other lead to computer pin 22 with a safety pin.
With the ignition switch Off, jumper the computer into self test mode like you are going to dump
the codes. Turn the ignition switch to the Run position. The light will flicker when the computer
does the self test routine. A flickering light is a good computer. No flickering light is a bad computer.
Fuel pump runs continuously: The fuel pump relay contacts are stuck together or the Tan/Lt Green wire
has shorted to ground. Remove the fuel pump relay from its socket. Then disconnect the computer and use
an ohmmeter to check out the resistance between the Tan/Lt Green wire and ground. You should see
more than 10 K Ohms (10,000 ohms) or an infinite open circuit. Be sure that the test connector isn’t
jumpered to ground.
If the wiring checks out good, then the computer is the likely culprit.
Prior to replacing the computer, check the computer power ground. The computer has its own
dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to
it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a
black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. You'll find it up
next to the starter solenoid where the wire goes into the wiring harness
If all of the checks have worked OK to this point, then the computer is bad. The
computers are very reliable and not prone to failure unless there has been
significant electrical trauma to the car. Things like lightning strikes and putting
the battery in backwards or connecting jumper cables backwards are about the
only thing that kills the computer.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
OK...So I was able to make a couple of test. I did get 12v Orange/Lt. Blue wire (power source for fuel pump relay). Then on the next step I did not get 12v at the Light Pink/Black wire (relay controlled power for the fuel pump). But I got a new really so I don't know. Then tested the third test and did get 12v Red/black wire on the relay. Then tested the two back wires on the inertia switch and got 12v. So it seems the problem is near the relay switch and just cant pin point it. Should I just buy another relay and see if the one I got was bad? Or is there an easier way to check?
Get a 15 amp fuse and about 20 ft of 14 gauge wire. You are going to bypass the relay circuit and apply power directly to the pump. Do not attempt this without the fuse!!! A short circuit could start a fire. Do not let this test run for more that 20-30 seconds to prevent dumping any gas into a non running engine. You will need a fuel pressure test gauge attached to the Schrader vavle behind the alternator to verify fuel pressure. Most auto parts stores will rent or loan test equipment like the fuel pressure test gauge. Look for 37-41 PSI when the fuel pump runs.
Disconnect the fuel pump at the connector back by the passenger side spare tire wheelwell. Store the body side connector out of the way so that it will not be damaged. Take the wire that goes to the fuel tanks and both black wires to ground. Connect the pink wire that goes to the fuel tank to the fused jumper wire. Finally connect the fused jumper wire to the positive side of the battery. If the fuel pump runs and you have fuel pressure, the problem is in the relay circuit and wiring. If not, it is in the fuel pump or the short harness that you connected your jumper wires to.
Well I got it started. Thx for all the help. So I by passed everything and put a line with a fuse directly to the pump. Every time I turned it on it blew the fuse. so by now I was just frustrated and ran it with out the fuse. And yup it started. And then out of a sudden I noticed the wires from the float started smoking. So it turns out I guess those wires are bad or the float. I disconnected it and now everything is fine. So now I guess I got to fix that problem. thx for all the help...
Blowing the fuse means that either the pump is bad or the wires that connect to it are shorted to ground. Running it without a fuse is very hazardous since an electrical fire around or in the fuel tank could result in a major fire and explosion.
