help with Ground Wires
90mustangfan
93
So cal
where are all the ground wires in the engine bay... could somone post a diagram of where all the ground wires are...I think im missing the one that goes from the block to the firewall and the one for the O2 sensor ...where are they....
Block to the Front dash (AKA firewall) should be on the left front near the brake booster and running to the back of the left head.
Didn't know there was a ground for O2 sensors
yea i only thought it was the two from the factory..well and the one that goes to the stock hood..but you can never have enough grounds..but i'm with srothfuss..those two and the hood..no dea there was a seperate one for the O2 sensors..wouldnt they just be grounded through the harness?
I dont have the ground wire from the heads to the firewall...and my negative battery cable goes to the front of the driver side heads...I thought the Negative battery cable should ground on the body...will this effect anything? could this be why Im getting codes 41 and 91....Ive read back a couple of posts from the search and I found this....
"QOUTE" Long story short, I've been getting codes 41 and 91 ever since I had some engine work done a couple years back. It was strange too. The car would run fine, and the idle was good, but it would run rich, and after it warmed up my CE light would come on and stay on.
I changed my injectors this weekend because one or more were sticking open and getting fuel in my oil. After I got the new 24's in, it ran better, but I still got the 41/91 codes.
I spent a few hours Saturday night looking through all the code 41/91 threads I could find here and on Stangnet, and I found a couple that mentioned a orange ground wire for the O2's. I had already ordered the Ford sensor kit to change out my O2's, and also the TAB and TAD solenoids that sometimes can cause a 41/91 condition.
So, it was a nice day today so I figure I'll try to locate this wire since the motor was out back when they did the work to it, and they might not have connected it back. I couldn't find the wire at first, but I noticed my 10 pin connections had been pushed way down near the bellhousing. I pulled them back up since it might get a bit too hot down there, and I noticed a wire coming down below them with some heat shield type sleeving on it. I pulled on the wire, and sure enough it came up to a unconnected ring terminal, that had been crimped onto a length of black wire, which had been simply spliced via twisting ends together, and taped over with electrical tape.
Anyway, I cut the added length of wire off, stripped the ends of the orange wire, soldered on a length of 12ga wire and covered with some heat shrink, and finally, put a ring terminal on the end. I sanded off a spot on the firewall where there was a screw hole, and screwed the terminal there.
What a difference! Not only are all codes gone, the car runs SO GOOD now. I guess I've been running in "limp mode" for more than two years...heh.
Anyway, thanks to this forum, I finally beat this pesky issue. I hope this thread may help someone else down the line as well as this seems to be a fairly common issue. Also, trying to search for 41 or 91 is pretty damn hard when you can only search for things that are 4 characters long...oh well.
I still can't believe that one wire was the cause of all that trouble...
Grounds are important to any electrical system, and especially to computers.
1.) The main power ground is from engine block to battery: it is the power ground for the starter & alternator.
2.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects.
3.) The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. The wire goes into the harness at the starter solenoid.
4.) All the sensors have a common separate ground. This includes the TPS, ACT, EGE, BAP, & VSS
5.) The O2 sensor heaters have their own ground (HEGO ground) coming from the computer. This is different and separate from the O2 sensor ground. It is in the fuel injector wiring harness and comes out under the throttle body. It gets connected to a manifold or head bolt.
6.) The TFI module has 2 grounds: one for the foil shield around the wires and another for the module itself.
7.) The computer takes the shield ground for the TFI module and runs it from pin 20 to the chassis near the computer.
8.) The computer's main power ground (the one that comes from the battery ground wire) uses pins 40 & 60 for all the things it controls internally.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103#volt for help troubleshooting voltage drops across grounds
Code 41 or 91 - O2 indicates system lean. Look for a vacuum leak or failing O2 sensor.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel. Many times the end result is an engine that runs pig rich and stinks of unburned fuel.
The following is a Quote from Charles O. Probst, Ford fuel Injection & Electronic Engine control:
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than 400 Millivolts. Remember lean = less voltage.
When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than 600 millivolts. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage." End Quote
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter.
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are disconnected and measure the resistance from the O2 sensor body harness to the pins on the computer.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter. Do not attempt to measure the resistance of the O2 sensors, it may damage them.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
A missing O2 sensor ground can cause O2 sensor problems.
