Help with K-Code Compression Test Results
  • Thread starter Thread starter kyudizky
  • Start date Start date Jan 11, 2009
K
kyudizky
12
  • Jan 11, 2009
A little history-I’ve had my 65 K-Code for 3 yrs. and I’ve not been in the motor and don’t know when it was last worked over. Since I’m going to do the Mustangs Across America, I want to get it right. I did a compression test and numbers 1 thru 6 all were within 10% of each other with 5 cylinders being 170 and one 160. #7 was only 130 and did not come up any after adding a tsp. of 30 wt. so I know I have a valve problem there. #8 was only 130 but did go up after adding the oil. My question is-Why only 1 cylinder showing ring wear? The first couple of yrs. I had the car, if I drove it for some time at real low RPMs like in a parade, I would start seeing white looking smoke after a while. The temp. would never go above about 190. Last summer it got to were I can’t drive it at slow speeds at all without it running hot. I put in a new thermostat and added an aluminum radiator (already had an elect. fan and I don’t think the bottom hose is collapsing) and it didn’t help any. Is this a completely different problem or is it related anyway to my compression test results? I would definitely appreciate any advice on what I should do.
Thanks for your help!!!
mrmustangman357
763
Jan 11, 2009
  • Jan 11, 2009
does the oil look chocolatey? maybe you could have blown a head gasket, or the rings need to be done in the motor and/or valves. its interesting you got low readings on cylinders next to one another. do you have access to a leakdown gauge? That can better point you to where the leakage is occurring i.e. head gasket, head, rings, etc
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
D
Engine Questions on compression test results
  • dqureshi06
  • Jan 6, 2025
Fox 5.0 Mustang Tech Jan 7, 2025
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 23, 2026
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 10, 2026
gkomo
