help with lifters
  • Thread starter Thread starter jssblues
  • Start date Start date Jul 19, 2008
J
jssblues
31
  • Jul 19, 2008
just got my motor back from machine shop and i am starting to reassemble, all the roller lifters drop right in except for one, it doesnt want to fall all the way in.
could i try lightly tapping it with mallet????
Bullitt347
I have been doing it wrong this whole time
4,020
3,018
204
Middle of Maine
Jul 19, 2008
  • Jul 19, 2008
Inspect for burrs, (machine shop should have honed the lifter bores) inspect the lifter, try a different lifter in the same bore, if a different lifter will not go all of the way down, (how far down does it go?) then try lots of prelube and work it up and down some and see if it will drop in. I have had some lifters do the same thing, and sometimes just working it a little bit will get it to go in. Do not force it, if it will not go, then maybe you need to take to block back to the machine shop for a closer inspection.
Fast63
717
  • Jul 19, 2008
are you sure it isn't riding on a cam lobe that is around peak lift?
Vipersix
434
Clarksville, TN
Jul 19, 2008
  • Jul 19, 2008
No mallet!!
Sometimes my favorite philosophy works (If it doesn't fit, force it; if it breaks, it needed to be replaced anyway.) but it is by no means warranted in this situation. Do Bullitt347 recommended. If a different lifter does not fit, it is a problem with the block and you need to bitch at your mechanic. Obviously you should ensure that you are not simply being limited by a raised cam lobe though.
ShortThrow50
923
Pa
Jul 19, 2008
  • Jul 19, 2008
A MALLET?????? ARE you crazy dude?
I always use a 8 pound sledge
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
D
Theft light staying on car starts right up
  • dtarang
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 15, 2026
dtarang
D
