Hey Guys,
I put together an 8.8 from a 92 stang. Consisted of the 92 housing, FRPP 31 spline axles, and a 31 spline Trac-loc carrier from an explorer (early 90s).
Is there anyway for this combo to work. It all fits together but the exploder carrier is wider, the axles stick in quite far. No matter what thickness clutch pack i put in, i can't get any combination to work.
With a stock thickness clutch pack, the axles when seated in the tubes in the right position (seals on seal surface, the axle sticks about 3/8" past the side gears and clutch pack.
The exploder carrier uses a bigger cross pin than the mustang, but either the axles stick in too far, or i can't get the spiders to roll in.
Im pulling my hair out over this one.
Do I have to buy a 31 spline carrier specific for the mustang axle??
Any help is greatly appreciated. The races i am going to are less than a month away and i don't want to run with 2.73s
Thanks in advance.
Mike
Thanks in advance.
Mike
