Help with stripped oil pan plug hole
Boy, I don't know. That's not a common one to strip! Maybe take the plug to Home Depot and compare.
You could find a larger drain plug and tap the pan for the new plug, but be careful not to get metal shavings in the pan. If that doesn't work, you might be stuck pulling the pan and having it welded/ retapped.
