Help with transbrake/valvebody install.
allcarfan
The Answer Man
2,458
North Atlanta
I just bought a reverse manual valve body with transbrake from a fellow stanger.
There are two wires that come off of the transbrake itself. One goes to a spaded terminal on top of a pressure regulator? (it says 54PSI on the side of it)(wire 2 in pic).
The other wire comes off the transbrake, and just has a spaded terminal on the end of it (wire 1 in pic). ON top of the "pressure regulator?" is another spaded Terminal.
I am assuming that I have to run another wire from the top of that pressure regulator and wire it to a button with a 12v source and the other wire that is off of the transbrake? Am I right on this?
There is also a hole labeled "OUT" on the transbrake...do I do anything with this hole? Its threaded.
Enclosed is a pic with some labels.
Help
Shane
Pic:
attachment.php
