  • SN95 4.6L Mustang Tech
Help With transmission
  • Thread starter Thread starter trublu46
  • Start date Start date Jun 13, 2005
T
trublu46
Carmel, New York
Jun 13, 2005
  • Jun 13, 2005
hi i have a 2002 GT Stang my problem is when i shift into secong gear the gear sounds like it grinds when im over a certain RPM. IS it a prbolem with the tranny or what?
Thanks
MAtt
slow96mustang
146
romulus mi
Jun 13, 2005
  • Jun 13, 2005
yeah sounds like tranny. i would try to change the fluid, and see if the problem still presists. if it dose, id take it somewhere and have them look at it. probally a syncro or something..... is syncro the right word?
tomustang
Psychotic Member
3,434
McLean Hospital
Jun 13, 2005
  • Jun 13, 2005
Thanks
MAtt
certain rpm? need more info.
still, the 1st-2nd syncros are bad at high rpm shifts. common problem in a T-45 but i don't knoe of 02's have than tranny.
twogts4us
4,188
12
79
Dunedin, FL
Jun 13, 2005
  • Jun 13, 2005
2002=3650.
Practice, maybe? I mean, I can grind it if I get sloppy. Are you saying this happens as you shift into 2nd at high RPMs, or after you are already in 2nd and you are increasing the RPMs?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jun 13, 2005
  • Jun 13, 2005
sounds like your not disengaging the clutch all the way. get a aftermarket quad/firewall adjuster and break that POS stock quad into a million peices and burn it. then adjust the clutch so the release point is higher.
T
trublu46
Carmel, New York
Jun 14, 2005
  • Jun 14, 2005
thanx all and ive heard bout the syncro i tihnk thats may be it. its not a miss of gear. when i rev over2 grand and dont let the engine wind down it grinds the second gear. thanx all
twogts4us
4,188
12
79
Dunedin, FL
Jun 14, 2005
  • Jun 14, 2005
Well that just isn't right. By the way, Welcome to StangNet!
Sounds like you'll need to have Ford take a look at it.
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
